I probably need shocks. Suggestions?
Old Mar 27, 2017 | 08:13 PM
Alien c4's Avatar
Alien c4
Default I probably need shocks. Suggestions?
My 98 coupe has 82k miles and is on the original shocks.
I'm just a street driver, occasionally spirited but no auto cross or track days so I don't need anything racy (read: expensive).
Just looking for regular duty shocks to replace my current used up set.
What would you buy?
Looks like three bolts per shock. Is it a relatively simple installation?
Old Mar 27, 2017 | 08:34 PM
chris308's Avatar
chris308
C6ZO6 or Bilstein HD
Old Mar 27, 2017 | 08:40 PM
I would get C6 Z06 shocks - a nice upgrade over the stock C5 shocks and priced reasonably.
Old Mar 28, 2017 | 10:06 AM
Macleod52's Avatar
Macleod52
+1 on C6 Z06 shocks. Right around $300.
Old Mar 28, 2017 | 10:18 AM
Alien c4's Avatar
Alien c4
$300 for 4 new ones?
Old Mar 28, 2017 | 10:33 AM
Macleod52's Avatar
Macleod52
Yep. Check out some of the various vendors on the forum. I got mine from Gene Culley & Cultrag.
Old Mar 28, 2017 | 10:42 AM
Sydwayz's Avatar
Sydwayz
St. Jude Donor '18
Me too, great upgrade. Throw in the Z06 sway bars and links too while your at it. It's one of my favorite upgrades to my car; GREAT bang for the buck, that you can feel the first corner you take.
Old Mar 28, 2017 | 02:13 PM
02BlownZ06's Avatar
02BlownZ06
I put Bilstein HD's on and I like them. They were recommended if you lower you car and mine is lowered. Pretty firm ride but works good in conjunction with lowering your car.
Old Mar 28, 2017 | 02:25 PM
unlvrebel's Avatar
unlvrebel
Originally Posted by shootnstarz
Oh yea, you will most likely have to cut a slot in the plastic cover on the old shocks so you can get vice grips on the shaft, otherwise it just spins when you try to de-nut it.
RH
Or use a strap wrench.
De-nut it... I love it!
Old Mar 28, 2017 | 02:27 PM
unlvrebel's Avatar
unlvrebel
What would you buy?
I'm in the same boat. Got 108K on mine. I've a thread in the Tech section. Seems that the general consensus is C6 Z06 shocks and replace the sway bars.
Are you anywhere near the Tampa area? Always good to go through surgery with a friend!
Old Mar 28, 2017 | 02:29 PM
Alien c4's Avatar
Alien c4
No, I'm in Pa. but If I were closer, id be in!
Old Mar 28, 2017 | 05:54 PM
twokbolt's Avatar
twokbolt
I just went through this myself and went with the c6 z06 shocks. Car now rides like it should have from the factory. Mine was an 04 with 72k miles. I used this site as a guide. You do not need to remove the washer tank or the overflow tank (or at least I didn't have to).
http://www.pcfred.com/Vettetip/C5%20Shock%20Install.htm
Old Mar 28, 2017 | 06:31 PM
subchev's Avatar
0subchev
Former Vendor
1997-2013 CHEVROLET C5 C6 CORVETTE GENUINE GM C6 Z06 SHOCK UPGRADE KIT
I have these shocks on My C6 Grand Sport and I love how they respond to the road.
Even slow, the bumps aren't very bad, and then when you get up to speed they handle great and respond to the road very well.
Old Mar 28, 2017 | 06:40 PM
furious427's Avatar
furious427
I have set of 30,000 mile 2004 C5 Z06 shocks I would like to sell if your interested, they are really clean and in great shape.
Old Mar 28, 2017 | 07:07 PM
Alien c4's Avatar
Alien c4
Originally Posted by furious465
I have set of 30,000 mile C5 Z06 shocks I would like to sell if your interested, they are really clean and in great shape.
Please send me a pm with pics, details and price shipped to 18328.
Old Mar 28, 2017 | 08:51 PM
buckeye1872's Avatar
buckeye1872
I used these same instructions. No removal of tank required. Check Rockauto out. I got the C6Z06 shocks for $227 shipped. Also did the sways and links, got them Cultrag.
Old Mar 29, 2017 | 10:07 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
Thank you for the referrals and for your business. People know where to get their parts!
To I probably need shocks. Suggestions?
Old Mar 29, 2017 | 11:20 PM
jwh172's Avatar
jwh172
If you are lowered and are considering the Bilstein's, you should get the DRM valved Bilsteins. I have them on my C5Z and they are great on the track and street. They feel more planted to the ground but they arent as stiff as the Bilstein HD.
When i had the stock Z06 shocks on, the car would skip if i hit a bump while cornering. If i were to take an on ramp at a "fun" speed, the rear end would lose grip and kick out at the concrete seams. However, the DRM Bilsteins are stuck to the ground the whole time and they don't feel any more harsh than the stock shocks.
Old Mar 30, 2017 | 09:54 AM
The Rabbi's Avatar
The Rabbi
2018 C5 of Year Finalist
St. Jude Donor '14,'18
I drive like you and replaced with OEM.
Old Mar 30, 2017 | 01:14 PM
soofrsh's Avatar
soofrsh
I just swapped over to the c6 z06 shocks last week. Much better than the noisy base shocks.
