[Z06] Rear upper control arm squeaks and knocks
Old Mar 31, 2017 | 09:34 AM
RedBoy504's Avatar
RedBoy504
Default Rear upper control arm squeaks and knocks
I've been having this problem for a while now. Even changed the rear upper control arm. The new one does the same thing. I thought the bushings were worn so I changed the arm. No luck. Same issues. When I move it with my hands I can see movement in the bussing area. The bushings on the passenger side, where I'm having the issue seems to be smaller than the ones on the drivers side. Can I get any suggestions? Thanks in advance. Oh FYI it rides terrible on that side. You can feel every rock and pebble in the road.
Old Apr 1, 2017 | 09:16 PM
RedBoy504's Avatar
RedBoy504
The bolts are stripped. They won't get tight enough.
Old Apr 3, 2017 | 08:37 AM
ZEEZERO-6's Avatar
ZEEZERO-6
is it stock or do you have coilovers ?
Old Apr 8, 2017 | 10:48 AM
RedBoy504's Avatar
RedBoy504
Stock
Old Apr 8, 2017 | 10:49 AM
RedBoy504's Avatar
RedBoy504
Bolts are stripped and so is the nut on the rear. I'm in the process of trying to re thread it.
Old Apr 8, 2017 | 05:34 PM
RedBoy504's Avatar
RedBoy504
Re-threaded the nut and added a new bolt. It tightened up pretty good. The knock is gone. But it still squeaks like crazy.
To Rear upper control arm squeaks and knocks
