One down, one to go.
Old Apr 4, 2017 | 09:42 PM
calguy's Avatar
calguy
Default One down, one to go.
Put the new ignition switch in today, and that solved the problem with the starting.
While I have the consol apart, I removed the hvac box because the pesky old lights were, for the most part, not working, and the one that gives the temperature was so dim I couldn't read it.
I know many on this forum have rebuilt their own by soldering the circuit boards, but I am not good at that, and want to send it out to be repaired.
There was mention of some doing that, but no mention of who they sent it to for repair.
Any one know of someone who repairs these things?
Thanks,
Bob.
Old Apr 4, 2017 | 09:53 PM
sloopdawg's Avatar
sloopdawg
This is just one.
There are several around, maybe someone else can chime in with the others.
Old Apr 4, 2017 | 10:08 PM
SCvette1's Avatar
SCvette1
I went with Silvano at Corvette Solutions. I had him do a blue LED upgrade while in there and the results are awesome. He also replaced the buttons where some of the print has worn off. Looks brand new!
Old Apr 4, 2017 | 10:36 PM
jim993's Avatar
jim993
You could check
www.absfixer.com
also
https://modulemaster.com
Old Apr 4, 2017 | 10:52 PM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
Congrats on getting the switch sorted!
Old Apr 4, 2017 | 11:05 PM
Ducati Guy's Avatar
Ducati Guy
If u can replace the ignition switch i bet you can figure out how to solder the display.
You really cannot screw it up. I have done very little soldering in my life. Gave it a shot and even with doing a crappy job it was good enough to fix it. And if you fail then send it out.
Old Apr 4, 2017 | 11:14 PM
Glad you got the starting problem solved.
Old Apr 4, 2017 | 11:17 PM
FX VETTE's Avatar
FX VETTE
https://www.youtube.com/watch?v=RPXmZXUTgps&t=108s
Old Apr 5, 2017 | 01:45 AM
calguy's Avatar
calguy
Replacing the switch only took about a half hour from start to finish.
Left the consol out though because I removed the hvac box.
That dim light problem, and only two of the fourteen bulbs are working.
I could solder the 241'S, but the bulbs is another project I would rather leave to someone else.
I ordered another unit from Corvette Solutions tonight.
I will be getting it with the white led's to match the other lights in the dash.
Man I couldn't believe all the crud buildup under the consol.
Now that it's out, I have some cleaning to do.
This forum is the greatest;.
Once again, a big,big thanks to all who gave me advice with the problems I was having.
Bob.
Old Apr 5, 2017 | 01:51 AM
Rico7142's Avatar
Rico7142
St. Jude Donor '16
Old Apr 5, 2017 | 09:00 AM
glbeauchamp's Avatar
glbeauchamp
I sent mine to Dave Ruberg in Winona MN. 507-429-4489. He had it done and back to me almost before I knew it was gone. Glad to hear about your ignition switch. Had one go bad on my wife's Pontiac. It failed from lack of use I think as the car only goes out about twice a year.
To One down, one to go.
