Portable jump pack
Looking to see what my fellow C5 drivers are using for a portable jump pack and compressor. These things have come a long way and are pretty impressive. Looking at the RG1000 Safety Plus. Seems like a good package. I know that there are cheaper alternatives, but for the size and to include an air compressor is pretty impressive.
https://ruggedgeek.com/products/rg10...e-power-supply
What I like about the Rugged Geek and others is the size. Somewhere between your smartphone and tablet in size. Closer to your phone. It's crazy that something that small can start a car!
Thanks guys!
I was going to recommend that one (the larger Stanley) too! I have one like it, but years old now, and it's been great to take along on road trips, or just have handy. Also, it has 12 volt and other connections. I've started cars for people with it 3 or 4 times. Never needed to jump myself yet (knock on wood).
I also have the smaller JumpStarter unit the OP had in the link. Took it to China several times, and it does hold a charge for a long long time, and will charge up lots of phones and lap tops, cameras, KindleFire and all the electrical gadgets we carry with us (on vacations, etc). It never seems to run low, charging those things. Very impressive! I don't know it's limitations, because it's never run out of charge on me...
Never had to use it for a jump start yet, but it's behind the seat in case. I take it out every few months to re-charge, and it's always near fully charged already.
The smaller unit does not have a 12 volt (cig lighter) socket, and that is the only knock on it, for me. I've encountered several 'gadgets' that need that socket.
I have a 'memory saver' tool for my C5 (or any car). If I disconnect the car battery for some reason, just plug the memory saver into the OBD port on the car, and into the 12 volt plug socket of my Stanley. You lose nothing, while car battery is disconnected. But, it needs a 12 volt socket, so the smaller unit won't work for things like that. I suppose one could find an adaptor, maybe. Never looked.
So....I'd prefer the bigger Jump Starter unit, for that reason...if I had to pick just one.
Don
Put in the order for the Rugged Geek. Bee here on Thursday.
About the size if a paperback book, USB port, LED flashlight, multiconnector USB adapter.
Nice carrying case.
I know the battery in my C5 is weak when cold; 50/50 chance of starting when ambient was 35-45. And no chance when ambient lower than 35
In the 35-45 range, the 300 booster usually started the car.
Below 35, the 300/500 did not have the oopmph, so had to revert to standard cables and a second vehicle. PITA when i was parked in the (15 deg slope, tree and flowerpot lined driveway).
Since i also have a 6.2L, upgraded to the v10 version. (500/700 peak). size wise, it is slightly smaller than a hardback book. USB port, carry handle, light, but didn't ship with the multiple device adapter cable. About 100 on Amazon.
Since spring has sprung, and temps are up, no issues starting anything, so i have not needed to test the new one
YMMV and all that
UPdate: Whne I got home last night, neighbor 1 was using his old Chevy 1500 to (try to) jump start neighbor 2's Ram SUV. Lots of clicks, no crank, no start.
Grabbed the Wagan, both neighbors shook their heads ands said no way.
Started the V8 with no hesitation.
After I jumped few friends, they all own one.
I like the Rugged Geek since it has the mini compressor too. I've been dancing dangerously (no run flats, not slime and compressor) for too long.
Battery packs I have had didn't last very long and were not worth the money. I have a Harbor Freight compressor in the vert. Never opened, hope I never need it but if it works once or twice I'll throw it away when I'm done
For footballs, pool blow up items and air mattresses.
We have a large family and use the pool 10 to 12 months a year. Yeah, its in the low 80's now at 9:00am
https://no.co/gb40
I've used it numerous times on some of my vehicles and to help other people who were stranded. It's amazing how easily it will start any vehicle even 6L diesels. It charges through any USB and can be used to recharge anything that uses a USB like your cell phone, etc.
Steve
