C5 coupe rear speaker question
Old Apr 11, 2017 | 06:34 PM
tommyo4's Avatar
tommyo4
Default C5 coupe rear speaker question
I recently replaced the front with the Polk tweedlers 3.5 and they sound great so I wanted to get the matching Polk 6.5 for the rears. I pulled the stock one and the mounting holes for the new Polk don't match up at all with the stock holes or cut out.
Any idea how to mount this securely? I can't even drill 4 new holes because the circle cut out is slightly too large.
Any suggestions?
Old Apr 11, 2017 | 07:28 PM
Rob 02's Avatar
Rob 02
I have the Polk db651's and there was an adapter plate in the box with screws but I don't think you need them. 6.5"s should fit.
Are you sure you don't have 5.25" speakers? 5.25's would be correct for the FRC and vert.
Old Apr 11, 2017 | 10:13 PM
Rob 02's Avatar
Rob 02
I spoke to tommyo4 and here is what happened.
I recommended Polk Audio db651's for the rear. Polk Audio Makes a db651 and a db651s which is a slim line speaker that doesn't come with an adapter mounting bracket.
When I recommended the "db651's" he ordered the db651s. This was a miscommunication that I feel bad about and I will try to be more careful next time.
It costed him a few days an $9 to return them. Message my your address and I will send $9. My bad.
Glad you enjoy the front ones.
Old Apr 12, 2017 | 05:42 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
There have been many discussions on this subject, and many people say 6.5" speakers are what they use. In my car, I installed a pair of 6.75" Kenwood speakers, and the mounting holes lined right up.
To C5 coupe rear speaker question
