How do you remove/clean these?
Old Apr 11, 2017 | 07:51 PM
Alien c4's Avatar
Alien c4
Default How do you remove/clean these?
The speaker covers on the doors get a bit mucked up from dirty feet. How do you remove these for a proper cleaning?
Old Apr 11, 2017 | 08:03 PM
El original's Avatar
El original
See how to remove door panels....that is the only way if you want to clean both sides.
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
You need to remove the door panels. http://www.vetteessentials.com/instr...or_handle.html
Old Apr 11, 2017 | 08:13 PM
Ludeaem's Avatar
Ludeaem
i suggest a hand held steamer and a rag to blot, don't scrub
Old Apr 11, 2017 | 08:23 PM
glbeauchamp's Avatar
glbeauchamp
Thanks. My driver's side speaker cover got a little dented up from my knee while trying to negotiate my way out of the car. It's a little dirty, too.
Old Apr 11, 2017 | 10:40 PM
Great instructions and they will guide you through the removal and re-install process for the inner door panels. I've used those instructions several times.
Old Apr 11, 2017 | 11:23 PM
yanmar's Avatar
yanmar
Default Door speaker covers
WHEN I PURCHASED MY VET SEVERAL YEARS AGO THE DRIVERS SPEAKER HAD SCUFF MARKS,DIRT, THAT WOULD NOT COME OFF. I LIGHTLY SANDED AND SPRAYED WITH SATIN BLACK PAINT, THEY HAVE LOOKED NEW EVER SINCE. YOU MAY GIVE THIS A TRY. I DID NOT REMOVE THE PANEL.
Old Apr 12, 2017 | 07:19 AM
chris308's Avatar
chris308
there's a few videos on YT that show you how to remove the door panel on a c5 and other stuff like the window regulator...
Old Apr 12, 2017 | 11:40 AM
Mayor111's Avatar
Mayor111
Get yourself a $2 detailing brush at Harbor Freight (with longer bristles) and slightly dampen it, and use that to get the grill clean - works like a champ on getting all the dirt out of all the grooves.
To How do you remove/clean these?
