p1416 code fix
Old Apr 16, 2017 | 01:51 PM
wrs5835's Avatar
wrs5835
5th Gear
Default p1416 code fix
cost of replacing passenger side AIR check valve
Old Apr 16, 2017 | 03:06 PM
sloopdawg's Avatar
sloopdawg
15 to 40 bucks depending on the check valve you get
or do like I do and just reset it when the check engine light comes on...
cost $0 (just annoying)
Old Apr 16, 2017 | 03:46 PM
RedRiderZR1's Avatar
RedRiderZR1
Either tune it out or do what I did. Spray o2 safe throttle body cleaner in the driver side tube towards the passenger side valve and follow that up with compressed air. I put half to 3/4 can in that way and that error has been gone for years now. They don't usually fail just get all gunked up and stick.
Old Apr 16, 2017 | 09:57 PM
donald4972's Avatar
donald4972
St. Jude Donor '14-'15
OP, Take a look at this....
https://www.corvetteforum.com/forums...1416-code.html
Old Apr 17, 2017 | 11:10 AM
lane_viper's Avatar
lane_viper
This is by no means a difficult fix if you can do basic work. If you've ever done a battery or alternator, you can do this.
The part it around $10 at any auto parts store, so I replaced both driver and passenger sides. You will need to take off the intake maifold to access the back bolts sections, but it's easy to do. Refer to the links above and Google for a step by step procedure, and good luck.
To p1416 code fix
