mine is the top of the door glass gaskets both sides, drips a little in heavy rain.
No longer my daily so I try not to drive when I know there's expected rain in the forecast.
Just picked up a nice 2001...it had to sit out in a rain storm last night and now the passenger floorboard is wet.
Never had a convertible Vette before...is there a common place where they tend to leak? Thanks
Mine is 02 and used to be garaged but when I brought it to Hawaii (no garage) I discovered it leaks on both sides. When driving in rain, the water would stream along inside of side-glass coming from front seal along the A pillar. So I replaced the entire window seal along with the top seal. Done by GM dealership so you'd assume it was done correctly. Reduced the problem dramatically, but did not eliminate it. So I have a waterproof car cover now. At least it doesn't leak while driving or when washing the car. Maybe some one else has a better solution.
professor jim
My experience, hot humid day, running the A/C. Water started trickling down on my wife's feet close to the firewall...now no big deal, until some crazy electrical stuff started happening. Further check and the carpet was soaked and the water had got in to the plug for the ECM......read this thread
This little rubber hose is hard to find. In the engine compartment about halfway down the passenger side firewall. It's flexible rubber, stick your finger in and make sure it's clear. I unplugged mine and got a couple cups of water pouring down my arm....hope this helps.
Thanks for all the info - we live in a condo so a good cover (on order) is the only option beside trying to fix/stem the leaks....as the threads describe.
Its a Corvette and a Convertible so it leaks. That's why Harbor Freight sell shop vacs.
Seriously, most all c5 convertibles will leak some around window weather seals in heavy rain..
You can minimize this by treating weather seals with dielectric grease.
All C5 s can leak if drain utters get clogged. Many good threads on how to unclog here.
