What going on!!!!!!!!!!!
Old Apr 28, 2017 | 06:13 PM
namvet6869's Avatar
namvet6869
Default What going on!!!!!!!!!!!
Installed knew drl and parking lamp assembly today. While I had it apart I thought I would replace the bulbs since they were a pia to get to. I went with LED bulbs to reduce the heat. My problem is the turn signals blink super fast now. Do I need to go LED all around, different flasher or what. Also found out that LED's only work one way
Old Apr 28, 2017 | 06:41 PM
dbgoodwin's Avatar
dbgoodwin
You need a hyper flash relay. Google it and you will see.
Old Apr 28, 2017 | 07:03 PM
namvet6869's Avatar
namvet6869
Thanks for the reply. I figured that be the problem.
Old Apr 28, 2017 | 08:07 PM
El original's Avatar
El original
Is there any difference eg brighter than stock? I bought some LED's and could not figure out what the advantage would be aside cool bulbs but the in line resistor gets real hot if used for long time.
Old Apr 29, 2017 | 02:00 PM
crazybird's Avatar
crazybird
I had the same issue after installing new tail lights. Hyper flash relay fixed it.
Old Apr 29, 2017 | 08:30 PM
Mistrezz 06's Avatar
Mistrezz 06
To What going on!!!!!!!!!!!
