Chadwick paint correction
Old May 5, 2017 | 02:14 PM
Vanover's Avatar
Vanover
Originally Posted by DTA4
To get the swirls out did you use a buffer or do it by hand?
I used the buffer that came with the kit. I'll try again,I think I was being to cautious. This is the first time I have done a car.
Old Mar 28, 2018 | 02:31 PM
YO-EL's Avatar
YO-EL
Using the "dry" red pad #3 by itself won't scratch the paint?
For some reason, I can't comprehend this, a dry foam pad not creating micro marring/scratches, and am very apprehensive to use in lieu of the instructional video!
Can someone Please explain!
Thanks,
Old Mar 28, 2018 | 02:47 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Thanks,
when you use the red pad you are polishing the Chadwick's film off the surface, in doing so making the clear coat more perfect !!!! call Neil and he will answer all your questions !!!http://chadwickstripleplay.com/
Old Mar 28, 2018 | 11:12 PM
calguy's Avatar
calguy
Never used their products, but from the results, and the way it is applied, it seems to be like a fine cut rubbing compound.
Years ago, I used a fine cut rubbing compound on my pickup, and the results were the same as what I am seeing in this thread, which causes me to ask is the Chadwicks product a rubbing compound?
Bob.
Old Mar 29, 2018 | 10:02 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Originally Posted by calguy
never used their products, but from the results, and the way it is applied, it seems to be like a fine cut rubbing compound.
Years ago, i used a fine cut rubbing compound on my pickup, and the results were the same as what i am seeing in this thread, which causes me to ask is the chadwicks product a rubbing compound?
Bob.
no !!!!!
Old Mar 29, 2018 | 10:03 AM
imgn tht's Avatar
imgn tht
St. Jude Donor '13, '15
Has anyone ever used this stuff on a silver car? Looks good, but I'm struggling to justify the price.
Old Mar 29, 2018 | 10:13 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
night and day !!!!
grampi50's Avatar
grampi50
I also would be curious to know how heavy or fine the cut is. The term "paint correction" implies it has some level of abrasiveness to it, but I doubt its anything as course as a compound, as the use of a finer cut would be required after using the heavy stuff...it's probably more like a finishing polish in terms of abrasiveness, but I'd like to find out for sure...to the OP, your car turned out beautifully!
Old Mar 29, 2018 | 10:15 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
my truck (now sold) was as dull as could be, no paint correction just the Triple Play !!!170 plus miles and a 03 original paint !!!
Old Mar 29, 2018 | 10:17 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
it's a trade secret, but it's ingenious !!!!!!
Old Mar 29, 2018 | 10:38 AM
imgn tht's Avatar
imgn tht
Originally Posted by Pounder
night and day !!!!
It looks good and clean. I'm just not sold that mine wouldn't be just as clean using off the shelf products. And I'm asking specifically about the paint correction system not just the detail spray. Is that what you used? Did it do anything to make the metallic pop more?
Old Mar 29, 2018 | 10:46 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
it's not a detail spray it's cleaner, polisher ,and paint protector thus the name Triple Play !!! when I got my 99 I clay barred it and two weeks later a friend told me about Chadwick'. I told him I didn't think my car could look any better, but I would try it, I was shocked at the difference, and the more you use it the better it looks. Later Neil came up with the Paint Correction and wanted me to be a beta tester, again I was blown away, incredible difference !!!! Pictures do not do justice, you should see it in person, not sure I have seen any silver car shine more ???
Old Mar 29, 2018 | 11:02 AM
  #33
grampi50's Avatar
grampi50
I'm also curious to find out of it actually removes the fine scratches and swirl marks, or if it just fills them. A lot of today's products are nothing more than fillers, which eventually disappears and you're left with the same imperfections in the clear coat...I would rather use something that eliminates them...
Old Mar 29, 2018 | 11:08 AM
  #34
Pounder's Avatar
Pounder
1/4 mile/AutoX
it does eliminate them, does not take any clear coat off period !!!! and like I mentioned it's a trade secret. call Neil and maybe he will tell you everything you need to know !!http://chadwickstripleplay.com/
Old Mar 29, 2018 | 11:32 AM
  #35
grampi50's Avatar
grampi50
It's physically impossible to remove scratches without removing any of the clear coat...
Old Mar 29, 2018 | 12:31 PM
  #36
calguy's Avatar
calguy
I am inclined to agree with this statement.
Bob.
Old Mar 29, 2018 | 12:56 PM
  #37
Pounder's Avatar
Pounder
1/4 mile/AutoX
wrong !!!!!!!!!!!
To Chadwick paint correction
Old Mar 29, 2018 | 01:06 PM
  #38
usgecko's Avatar
usgecko
St. Jude Donor '13,'14
If it doesn't take clear coat off - it must be filling the scratches?
Old Mar 29, 2018 | 01:10 PM
  #39
grampi50's Avatar
grampi50
wrong !!!!!!!!!!!
Okay, unless you're adding more clear coat, then you're removing it, or a filler is being used to fill the scratches. Those are the only possible ways of making scratches disappear, or am I supposed to believe this stuff is magic?
Old Mar 29, 2018 | 01:25 PM
  #40
imgn tht's Avatar
imgn tht
The guy without a Corvette yet makes a good point here.
