Absolutely NOT
Use the 5w30 that GM designed the bearing clearances for
Only would use 10w30 in a VERY Hot Environment or if bearings were
quite loose
If you don't start your car in cold weather 10W30 is just fine. At operating temps, both 5W30 and 10W30 are the same viscosity oil.
5W30 is recommended because it covers starting the car in all climate situations. W means winter. Look in your owners manual.
I would not use 5w20 0r 10w40.
Use Mobil1 high Mileage. It has more Zinc and seal conditioners.
IMHO, 85K is not really "high mileage". The regular Mobil-1 with the Dexos1 label will work just fine. I just bought two 5 quart jugs of the regular 5W-30 from Amazon; $22.95 per jug and free shipping with Prime. When Costco has a sale of the 1 quart bottles in a 6-pack I'll get one of those too. The quart bottle with the 5 quart jug is enough for an LSx engine.
Same price, better additives. No brainer.
It's not only the miles, it's age. Some of these cars are 20 years old and additives that condition the seals are a good thing.
I'm using Mobil 1 5-30 high mileage because I read that the additive package is almost the same as "ordinary" Mobil 1 was when our cars were new. Maybe someone could confirm/deny?
My car has around 75k. Uses no oil between changes (never has), has good oil pressure and no rattles, so I guess all is OK.
I don't know if it actually makes a difference, but I'm convinced the high mileage is the better option for a typical C5. Higher zinc and phosphorous compared to regular Mobil 1. It also has more group IV PAO, which is closer to the old Mobil 1 formula in use when the C5 came out. The new Mobil 1 is mostly group III base stock.
The high mileage Mobil 1 actually doesn't meet the latest dexos standard or whatever and when I investigated I found out it's because of the higher phosphorus and zinc. The latest dexos just requires the "greener" catalytic convertor friendlier lower zinc/phosphorus oil. I'm sure you can use regular Mobil 1 with good results, but at the same price, I like the high mileage formulation. I started using it at around 60k miles.
Changed oil/filter yesterday Mobile one 10w30. Only had 3700 miles on oil change before that but it was 2 years old according to records. 03 Coupe only has 110,505 miles on it at oil change. It's all good. ;-)
Any reason anyone can think of not to use mobil1 5w40 ? Local Napa dealer said it just has a wider temperature range that it will perform well at.
Think of it this way you have to pour one gallon of fluid through a screen and down a tube because there are components at the end of the tube needing lubricant. Would you rather have the 30 weight get there and lubricate like it is designed to do or would you rather have a thicker fluid take longer to get to the parts. The engine was designed for 30 weight and the tolerances are specific to that weight oil 40 will increase pressure at the sacrifice of flow.
...and 40 wt. would lead to higher operating temps and lower HP.
I've done this homework before, for my motorcycles, don't know why I didn't remember it. Anyway, the 5 indicates the cold viscosity, the lower the number the better it will flow at cold temperatures. W just indicates winter, meaning it is formulated for year round use. The 30 indicates the oil viscosity at 100 degrees temperature. So, v8srfun is correct, with 5w40, flow will be reduced at normal operating temperature. Guess I'm doing another oil change. Dammit, I knew this.
