Lowering Problem
Thanks in advance!!
If you get it out, be sure to chase the threads with a tap before you reinstall the bolt.
If the blaster does not work it isn't that bad the way it is I'll just leave it the way it is and be happy. What do you expect from a 15 year old car that still kicks ***?
Decided I would just hack the bolts flush with the bottom of the spring. Thought was that if it sat too low I would just replace the spring. I absolutely love the stance now with the front bolts gone. There is no wear on the spring from where it rests on the control arm. Goodluck!
Well that is a different approach to the problem. Do you have any pictures of the way it sits? Did you do anything to the rears? Thanks for the idea.
FWIW, I'm the original owner of my '01 C-5, (with the F45, by the way), and it sat up like a 4x4, when I first took delivery of it. It was lowered, several months later..........
I really think you are right!!
My only suggestion, besides being very patient, would be to put a few drops of oil into the top if the bolt/insert interface, and let it sit for a few days, and hope it "wicks" down into the threads. Maybe even do this 2-3 times. Then when you're ready to try and turn the bolts, spray some lube on the exposed portion of the bolt, under the spring, which would help the bolt turn, as it goes up into the insert.
One other suggestion....on the top of the bolt, put a drop of paint, to use as a reference, so you can tell how far you've turned the bolt, so you can replicate it on the other side of the car. I'd also suggest using a socket, when turning the bolt, rather than an open end wrench. This will lessen the chance of rounding off the hex.
Good luck.
(FWIW, I lowered my car between 1" and 1.25")
