Dash Lights
Old May 17, 2017 | 02:20 PM
Red Rag Top's Avatar
Red Rag Top
Default Dash Lights
I just noticed that the RPM/X1000 legend in the tach is not illuminated when the car is running. The MPH legend lights even in the daytime with all exterior lights off but the RPM/X1000 doesn't.
I'm assuming it should be light any time the MPH legend in the speedo is illuminated. Am I looking at having to pull the dash to replace a bulb?
Old May 17, 2017 | 05:52 PM
SG Lou's Avatar
SG Lou
Yes Sir, you assumed correctly.
The bulbs are real tiny.....
Old May 22, 2017 | 02:36 PM
Red Rag Top
Any idea how many bulbs are required to replace all the bulbs. Is 12533422 the correct part number?
Old May 22, 2017 | 03:15 PM
SilverC54me's Avatar
SilverC54me
The RPM/x1000 legend does not light up. The MPH KPH lights up when you switch between English and Metric.
All markings on the face of the gauges are lit by black-light tubes from the sides of the cluster. If you look carefully at night you will see a purple glow from the sides.
So, all that to say your cluster is OK. No need to change any bulbs yet.
Gary
Old May 22, 2017 | 07:19 PM
FX VETTE's Avatar
FX VETTE
To Dash Lights
