Gains expected
Old May 19, 2017 | 06:39 AM
Randell Fuqua's Avatar
Randell Fuqua
6th Gear
Default Gains expected
hey guys I'm currently doing a build on my 98 vette Im putting an LG Executive cam kit, 92mm FAST intake, LS6 Heads, long tube 1 7/8 headers, C5 Z06 H pipe, with magnaflow cat back exhaust. I was wondering what kind of power gains I could or should see out of this set up.
thanks
Randell Fuqua
Old May 19, 2017 | 04:21 PM
Roddy13's Avatar
Roddy13
If you didn't look into this info before you picked the above parts I would be surprised.
Without the cam you should see 330-350whp... post the specs of the cam and we'll tell you where you can expect to be... likely slightly above or below 400whp.
Old May 19, 2017 | 06:56 PM
Smoken1's Avatar
Smoken1
Are you planning to go FI? Most ppl use the 1 3/4 for NA cars
Old May 20, 2017 | 10:50 AM
CactusCat's Avatar
CactusCat
I have a 98 as well. The stock motor is factory rated at 350hp (that's at the crank). The dyno will show you that at the rear wheels, you have about 290-300 rwhp (due to drive train loss - auto loses more than a manual). With the components you're showing, you be somewhere around 450-475hp at the crank and about 385-410rwhp. The reasons for the variance is due to the previously stated issue of cam specs we don't know. Also, dynos can vary from unit to unit. Suffice to say, you'll be somewhere near 400rwhp when done and you WILL notice the difference.
Old May 20, 2017 | 02:12 PM
zeevette's Avatar
zeevette
I think the LG Exec is 228-232/114E. Should really feel the difference!
Old May 20, 2017 | 09:01 PM
soofrsh's Avatar
soofrsh
at least do an x pipe with the rest of the exhaust being done
To Gains expected
