Active Handling Dangerous
Old May 20, 2017 | 08:05 PM
UM Rebel's Avatar
UM Rebel
Default Active Handling Dangerous
Was driving on I10 this afternoon smooth and straight. All of a sudden brakes start doing crazy stuff nearly making me swerve into off the road. Active Handling lights up in DIC. Then Low Trac warning lights and Service Active Handling lights in DIC. Code show C1286H - A malfunction of steering wheel speed sensor. I disconnected the sensor until I can get it replaced. This is a "Safety Feature" I could easily do without!
Old May 20, 2017 | 08:21 PM
Bluefire's Avatar
Bluefire
It is very scary when it goes out. Mine jerked me into the center lane (from the left lane) on the freeway. Thankfully, no one was there.
It works well... when it works. I turn it off at the track
Old May 20, 2017 | 08:25 PM
acuevo's Avatar
acuevo
Yikes thats scary. That makes me want to turn it off all the time now.
Old May 20, 2017 | 09:31 PM
coia96vette's Avatar
coia96vette
That happened to me on my '04. Pretty scary when it happens. That is the SWPS taking a crap. If your car is a '01 or newer the part number is 88965543. They cost about $70 and take 2.5 to 3 hours to replace. The older ones are no longer available new and can only be found used. Since I have replaced mine a few years ago I have not had any problems since.
Old May 20, 2017 | 09:32 PM
Choreo's Avatar
Choreo
Wait until all the electronic safety crap they pile on these new cars for an extra $20,000 goes South. I can see it ejecting me out on to the pavement, backing up, then running over me!
Old May 20, 2017 | 09:38 PM
Black 03 Z06's Avatar
Black 03 Z06
Scary business. Not a fan of all this electronic stuff. It will limit the life of our cars.
Old May 20, 2017 | 09:42 PM
Having the car jerk suddenly to the side would make you pucker a bit. Glad you did not end up hitting someone.
Old May 20, 2017 | 09:48 PM
Quickshift_C5's Avatar
Quickshift_C5
Mine was doing that as well due to a bad lateral accelerometer. I did the same as you. After about the 4th time, I pulled over and disconnected the steering position sensor. That was 3 years ago and I never reconnected it... Car has been in heavy downpours, freezing weather, and is riding on R Compounds with 640rwhp. Stability control system caused more problems than it prevented.
Here it is flaking out on the dragstrip at over 120mph when everything was suppose to be off.
Old May 20, 2017 | 09:50 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
turn of TC and its not an issue.....at least you can get a new one for an 04
Old May 20, 2017 | 09:56 PM
Quickshift_C5
Not true... System can still fault, as shown in my video. I had everything off for the drag pass and doing burnouts.
Old May 20, 2017 | 09:58 PM
dbgoodwin's Avatar
dbgoodwin
Hm. When mine acted up it literally just pulsed the abs pump and pulled ever so slightly to one side. Drove like that for several weeks with it happening, certainly wouldn't call it a safety issue for my case.
Old May 21, 2017 | 01:46 AM
Crosis's Avatar
Crosis
Exactly why I am in the hunt for a classic muscle car now. No computer anything.
Old May 21, 2017 | 09:17 AM
Slo Yelo C5's Avatar
Slo Yelo C5
1.) How do you disconnect the SPS?
2.) When you disconnect the SPS, you are still able to drive the car? And it doesn't cause any other issues?
Old May 21, 2017 | 09:50 AM
rrwirsi's Avatar
rrwirsi
My dream is the return of a C2 like Vette with ability to select AC, Power Windows, Power Doors, Power Seats, etc.
Old May 21, 2017 | 10:38 AM
UM Rebel's Avatar
UM Rebel
Sensor is plastic ring around the steering column located on the floorboard where the column goes into the firewall. Connector is on left side of sensor. Just unplug it
Yes you can still drive the car. DIC will show Service Active Handling And amber Low Trac Warning will be illuminated. Active handling button on console then only turns Traction Control on or off.
ABS will still work.
Old May 21, 2017 | 01:13 PM
whalepirot's Avatar
whalepirot
Got that 'tee shirt' in BMW and Subaru colors!
Simple STILL works.
Old May 21, 2017 | 03:42 PM
friou's Avatar
friou
I've gotta go with your thinking. If I've got AC, power windows and tunes I'm a pretty happy guy. I don't want any damn car making decisions for me, such as locking my doors after starting the car etc. Irritating! I'll take simple just about every time! Best wishes!
To Active Handling Dangerous
Old May 22, 2017 | 08:28 AM
bigcypress's Avatar
bigcypress
i agree , when buying a car now you may want one option and it only comes in a package with 5 or 6 others you don't want . GREATLY ANNOYING . . . . and expensive . . peace
Old May 22, 2017 | 04:44 PM
Nabcoinc's Avatar
Nabcoinc
If this is such a safety issue why hasn't GM issued a recall on it....seems like it is an issue based on the responses here.
Old May 22, 2017 | 04:57 PM
StrangelovesM6Vert's Avatar
StrangelovesM6Vert
Several threads on this.
Not enough of a problem to warrant a recall.
https://www.corvetteforum.com/forums...eck-today.html
https://www.corvetteforum.com/forums...-accident.html
