C5 Options
Old May 25, 2017 | 10:15 PM
C5 Newb's Avatar
C5 Newb
Default C5 Options
When I tracked down the options on my car I understand all of them but three. I know you guys & gals would know what they mean.
The
MN6 - Merchandised transmission?? Whats that mean?
R92 - POMS expedite / sold orders?? not sure on this one either..
IL3 - Trim interior L3 (base for AQ9) What's an AQ9 ???
AGZ - 6 way power passenger seat
AK5 - Driver / passenger air bags
AQ9 - Driver / passenger reclining sport seats
B6R - Bowling Green Kentucky plant build
B34 - Carpeted insert floor mats
CF7 - Body color removable roof panel
C60 - HVAC manual control
D25 - Roadside service decal
DL8 - Electric heated mirrors
D42 - Rear window shade screen
FE3 - Suspension system sport
GU6 - Axle ratio 3:42-1
JL4 - Active brake control
JL9 - Front & Rear ABS
K63 - 110 amp alternator
LS1 - Aluminum 5.7L engine (346 ci.)
MM6 - Borg & Warner 6 speed manual transmission
MN6 - merchandised Transmission (??)
NB6 - California emissions certified
NK4 - Steering wheel sport leather
QD4 - Aluminum styled wheels 17x8.5 front / 18x9.5 rear
R92 - POMS expedite / sold orders (??)
T96 - Fog lamps
UL0 - AM/FM Cassette stereo
UV7 - Antenna in windshield
U26 - 6 Speaker Bose sound system. 4 speakers front / 2 speakers rear
U1S - Remote 12 disc CD changer
U52 - Inst. cluster electronic
VG6 - Standard bumper ( 5mph )
VG8 - Buyer notice label
V73 - Vehicle statement US / Canada
XGG - Tire front - 245 / 45 - 17 EMT (run flat)
YGH - Tire Rear - 275 / 40 - 18 EMT (run flat)
Z51 - Performance Handling Package
1SA - Option package 01
86U - Exterior Magnetic Red Metallic
191 - Interior Black
193 - Trim combo Leather / Black
Old May 26, 2017 | 12:19 AM
C5 Newb's Avatar
C5 Newb
I have looked at this a dozen times and didn't notice AQ9 was the sport seats...wow. ok.
The others I still am not sure of.
Can't believe 66 people read this and didn't know.....
Old May 26, 2017 | 07:48 AM
Murray Anderson's Avatar
Murray Anderson
Mn6 was the regular everyday standard transmission (4T65E)
I believe the Z51 option with different gearing was MZ6
You have AQ9 listed in your options as the sport seats
Old May 26, 2017 | 11:38 AM
aj98's Avatar
aj98
I alway though MN6 was simply MaNual transmission 6 speed
Old May 26, 2017 | 11:56 AM
3sACROWD's Avatar
3sACROWD
[QUOTE=Murray Anderson;1594818532]Mn6 was the regular everyday standard transmission (4T65E)
/QUOTE]
MN6 is the base standard transmission. It is not however a 4T65E which is an automatic transmission call out and not for a Corvette. The 4L60E is the automatc tranny for the Corvette. The 4 indicates 4 speed, the T indicates Transverse mount (front wheel drive) L would be Longitudinal mount (rear wheel drive), 65 or 60 is the family of transmission and the E indicates electronically controlled.
The Z06 has an M12 manual transmission which is geared a little more agressively. Not sure about Z51 package. I thought they had the MN6 but had the rear end ratio of a Z06.
I think the R92 indicates the car was ordered with the options by a specific customer vs optioned by GM to be placed on a lot.
Old May 26, 2017 | 12:38 PM
C5 Newb's Avatar
C5 Newb
So why have two different codes for the transmission? MM6 & MN6?
Old May 26, 2017 | 01:07 PM
MikeG37's Avatar
MikeG37
MN6 only means the car has a manual transmission. Lets the factory know it has a clutch pedal, wiring, console pieces, etc..
MM6 specifies which manual transmission.
*A Z06 would have RPO MN6 & M12
Old May 26, 2017 | 01:20 PM
Murray Anderson
[QUOTE=3sACROWD;1594820197]
/QUOTE]
Apologies..... I guess you can't trust info on this forum... my bad
Old May 26, 2017 | 01:54 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
RPO Codes: http://www.corvetteactioncenter.com/specs/
Old May 26, 2017 | 02:18 PM
ArtClassShank's Avatar
ArtClassShank
/QUOTE]
I believe all manual C5's use the same 3.42 rear end. The only difference is the transmission gearing itself. MN6 being LS1 cars, MN12 being LS6 cars.
Old May 26, 2017 | 02:21 PM
3sACROWD's Avatar
3sACROWD
[QUOTE=Murray Anderson;1594820716]
No biggie. Just trying to clarify for future reference.
Old May 26, 2017 | 02:22 PM
3sACROWD's Avatar
3sACROWD
[QUOTE=ArtClassShank;1594821069]
Now that you mention it, I think you're correct.
Old Jun 2, 2017 | 01:50 PM
C5 Newb's Avatar
C5 Newb
Thanks everyone for clearing it up for me....
To C5 Options
