C5 corvette badd day
Old Jun 2, 2017 | 12:21 PM
CK571's Avatar
CK571
5th Gear
Default C5 corvette badd day
I have a problem I hope you can help me. I turn the key to on, The gauges roll , but after the gauges come back to zero the gauge. The gauges bounce radically and I get the message low voltage, service traction control, service Anti skid, service car. If I try and start the car it turns over but refuses to start. What the heck is going on??????
Any input will be appreciated.
Old Jun 2, 2017 | 12:54 PM
Shaolin Crane's Avatar
Shaolin Crane
Sounds like a voltage issue. Check the battery.
Old Jun 2, 2017 | 01:05 PM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
Old Jun 2, 2017 | 01:18 PM
friou's Avatar
friou
Take your battery out and get it tested. Low voltage kicks off all kinds of funky stuff in C5's, they are very sensitive to low voltage. I had the same issue and it turned out to be a bad battery that was nearly brand new. Bought a new battery which solved the problem. Good luck!
Old Jun 2, 2017 | 01:30 PM
'Shifter's Avatar
'Shifter
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
Failing it being a battery, check your grounds...
Old Jun 2, 2017 | 05:42 PM
first place to start would be to check the battery.
Old Jun 2, 2017 | 06:39 PM
Fast Cars & Horses's Avatar
Fast Cars & Horses
ignition switches are prone to cause similar issues !!!
Old Jun 2, 2017 | 08:05 PM
SG Lou's Avatar
SG Lou
Start with the easiest first....Battery, then grounds, then ignition switch
Old Jun 2, 2017 | 08:41 PM
RIKKI Z-06's Avatar
RIKKI Z-06
Old Jun 3, 2017 | 02:20 PM
CK571's Avatar
CK571
5th Gear
Ok Battery Rated 700cranking, Battery 697 cranking. Voltage 12.74. Battery good. Is the a local position where most the grounds are?? Or do I just start at the motor start circuit and work out to the next system?????? Thanks
Old Jun 3, 2017 | 02:24 PM
CK571's Avatar
CK571
5th Gear
Default C5 Corvette BADD DAY
Old Jun 4, 2017 | 12:20 AM
aj98's Avatar
aj98
Might make sure theres not a water leak in the passenger footwell. May drip onto the CPU under there; the car acts like it has lost its mind when that happens....
Old Jul 18, 2017 | 02:52 PM
CK571's Avatar
CK571
5th Gear
Sorry for the late post. I checked the battery, all the grounds ( the one near the rear of the car, and starter were the worst. Replaced the ignition switch. It runs now . I just have to get through emissions and get new plates and I am ready to go. Thank you all for your input.
To C5 corvette badd day
