Steering wheels
Old Jun 5, 2017 | 01:51 PM
rod7's Avatar
rod7
3rd Gear
Default Steering wheels
Can I put a c6 steering wheel on a c5 ?
Old Jun 5, 2017 | 02:37 PM
Velocity_Vette's Avatar
Velocity_Vette
The only wheel that will bolt up no immediate issues is the 2005 four spoke wheel. The reason is because 2005 C6s use the C5 design steering column. For 2006-2013, the three spoke wheel has a different design for the spline and will not interchange without modification.
Regardless you will also require minor modifications to make the air bag work.
Old Jun 5, 2017 | 10:35 PM
striper's Avatar
striper
If you search around the C5 forum you will find people that have done it successfully. I mention this because I am attempting this myself. There is a little work in just finding the correct parts you will need to make everything function properly. Aside from the C6 looking better to me and it is also slightly smaller in diameter, I intend to have all the buttons function as they are supposed to. The first thing you will have to decide is do you want to be modifying the splines to mate to the C5 column or do you want to search for the steering column part that will allow the C6 wheel to just slide on. Luckily I found an unused column splined shaft. One person who did this is Matthewfld. You'll have to search to find his posts.
Old Jun 6, 2017 | 01:31 AM
JETZ's Avatar
JETZ
The 2005 wheel is called the 'Pillsbury Dough Boy' wheel. You want a better looking wheel, not worse. C6 2006 up .
frank
To Steering wheels
