Body Panel Composition?
Old Jun 9, 2017 | 01:54 PM
02BlownZ06's Avatar
02BlownZ06
Default Body Panel Composition?
Does anyone know what the body panels on a C5 are made from? Some type of composite or basically just a plastic? You always hear the term wrap ur azz in fiberglass but I had heard they haven't used actual fiberglass for quite some time.....
Old Jun 9, 2017 | 02:12 PM
Murray Anderson's Avatar
Murray Anderson
A number of contributors helped drive down the C5's weight, including the use of SMC body panels that had a higher content of plastic than ever before. The material, which is basically the same as used in the C6, was composed of about 40 percent resin--polyester, vinyl ester, styrene, or a blend of all three--33 percent calcium-carbonate filler, 20 percent chopped fiberglass, and the remaining 7 percent resins and hardeners that improve the out-of-mold surface finish.
Old Jun 9, 2017 | 02:21 PM
02BlownZ06's Avatar
02BlownZ06
Ahhhhhh...OK, so they are not only plastic, but have some fiberglass in them also. Thanks!
Old Jun 9, 2017 | 04:37 PM
jackthelad's Avatar
jackthelad
For maintenance and repair purposes, you treat the panels just like fiberglass - use typical parts store fiberglass mat, resin and hardener for any repairs. SMC panels have the advantage of being easy to volume produce to accurate dimensions using presses - no hand laying up needed.
To Body Panel Composition?
