C6 GT2 for a C5? possible?...
Old Jun 10, 2017 | 11:26 AM
ianmcgee67179's Avatar
ianmcgee67179
Default C6 GT2 for a C5? possible?...
I have a 1999 C5 and wanting to replace the suspension with a GT2 set up and wondering if a set of GT2 shocks will fit my C5?... if they are the same coilover I cant see them not fitting. just wondering if anyone knows the difference or if there are any differences between the C6 and C5 GT2 coilovers?...
Old Jun 10, 2017 | 12:10 PM
Scylla's Avatar
Scylla
The C5 and C6 use identical dampers, so coilovers should fit both unless something strange is going on. I couldn't turn up the actual spring rates on LG Motorsports' site, so my advice if you're considering one of these kits is to call a vendor and get some direct consultation on the product.
It sounds as though this is a Bilstein Damper kit with CNC mounts and spherical bearings(?). That would lead me to believe it's setup at higher spring rates than a C6 Z06. So you will be getting significantly stiffer spring rates, without a high end multi-valve damper, that sounds like a very harsh ride, but they are using high quality hardware, which would lessen the effects somewhat. If anyone has this kit, direct experience would be helpful!
Old Jun 10, 2017 | 03:56 PM
StingrayRebel's Avatar
StingrayRebel
pretty sure the gt2's are the same, the g2's are the ones built with custom spring rates and bilstein shocks... pm Anthony or give lg a call and they will know for sure
Old Jun 11, 2017 | 03:29 AM
ianmcgee67179
thanks! I will have to do that. Would Anthony know of a good place to get a lower price for a set of GT2's and G1 sway bars by any chance?!
Old Jun 12, 2017 | 01:17 AM
LG Motorsports's Avatar
LG Motorsports
Premium Supporting Vendor
St. Jude Vendor Donor '03-'04-'05-'06-'07-'08-'09-'10-'11
Call us at LG.
972-429-1963. 👍
To C6 GT2 for a C5? possible?...
