[Z06] 273 automatic differential help
Old Jun 17, 2017 | 01:08 AM
03z06u's Avatar
03z06u
Default 273 automatic differential help
Hey guys I'm putting a c6 differential in my c5 I have the 273 gear c6 differential from a grand sport but they don't have the speed sensor on the differential like 342 differential do. has anyone ever drilled the spot out on the cases and seen if it would work? I had a shop drill mine and still not reading my speedometer.
Old Jun 17, 2017 | 10:55 AM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Yeh. I've drilled out the boss and installed the vss sensor. Works great!
I installed a set of 3.73s in it too.
When you look into the hole, do you see the reluctor wheel?
Old Jun 17, 2017 | 12:31 PM
03z06u's Avatar
03z06u
It's a c6 differential so no just see the gear
Old Jun 17, 2017 | 02:37 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
Ok. If you only see the gear and not the reluctor, then that's why you don't have a vss signal.
From what I understand, the physical size of the 2.73 ring gear is different from the 3.15 and up. That's likely the issue you're having and why GM pulled the vss off the transmission on the auto C6 cars. Install a different ring and pinion and that should fix your issue.
Good luck!
Old Jun 17, 2017 | 04:04 PM
03z06u's Avatar
03z06u
Thank you sir
To 273 automatic differential help
By Michael S. Palmer | 2026-06-03 11:00:24
