Well sorta. Just didn't run a line from the battery negative to engine. Anyways, been having weird electrical things happening. I've only owned the car since April; my first corvette. Then the steering column lock code occurred so I felt it was time to address the issues. While installing the LCM5 bypass I went ahead and upgraded the ground wires along with a new power wire. I used Knu Konceptz 1/0 kolossus fleks kable, their fuse holder, and Sky High Car Audio copper lugs. I've used products from both companies many times for audio installations. Great stuff. Thought I would post pictures.
I use knukonceptz wiring in my C5 as well, good stuff. LOTS of 0-gauge including a run to the rear for the stereo's 2K wattage.
Of course, I did the Big 3 as well.
KnuKonceptz is on amazon. Better to visit their site. I can put together some part numbers if you need them. The copper lugs I purchase from Sky High audio. Those are the best I've found and they come with the correct shrink tubes.
