Wheel offsets C5 to C6
Old Jun 27, 2017 | 08:25 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Wheel offsets C5 to C6
The C5 Z06 front wheel offset is +57 for a 18x9.5" rim
I would like to put on C6 ZR1 wheels to clear my the new Z06 brakes I plan on putting on...
The C6 ZR1 front wheel offset is +40 for a 19x10" rim
The rim is approximately 1/2 wider, but the -17 in offset is .67"...
Will this rim fit or stick out?
Will it clear the Z06 brakes?
Old Jun 27, 2017 | 10:08 PM
Nyt_Muves's Avatar
Nyt_Muves
Fits on mine no problem. Mine is not a Z06 though. I have the wheels off an 09 lingenfelter (zO6 spiders) with the same offset and size. Nothing rubs.
Old Jun 28, 2017 | 12:28 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Can you please post pictures of your front and rear rims/tires?
Old Jun 28, 2017 | 03:00 AM
Nyt_Muves's Avatar
Nyt_Muves
Do these show what you wanted?
Old Jun 28, 2017 | 10:58 AM
ICULUKN-C5's Avatar
ICULUKN-C5
are these reproductions made for the C5 or OEM wheels?
Old Jun 28, 2017 | 01:25 PM
Nyt_Muves's Avatar
Nyt_Muves
OEM. Off an 09 lingenfelter.
Old Jun 28, 2017 | 01:31 PM
ArtClassShank's Avatar
ArtClassShank
willtheyfit.com is my goto for questions like this. Can't answer your brake clearance question, but I'd imagine a ZR1 rim would do just fine over C6Z brakes.
Old Jun 28, 2017 | 01:37 PM
Nyt_Muves's Avatar
Nyt_Muves
ICULUKIN, where are you, if you're near in happy to pull one off and help you test fit...
Old Jun 28, 2017 | 03:01 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Im in Ahwatukee... I would be happy to come to you on the west side on the weekend. Are you doing any events with ACE soon?
Old Jun 28, 2017 | 05:58 PM
Nyt_Muves's Avatar
Nyt_Muves
Love too. Still need to do an oil pan gasket before driving much. As I'm looking for work at the moment it has taken priority and the three times I've set aside lately to do it I've gotten side tracked by job interviews.
Old Oct 1, 2017 | 12:01 PM
CJ1957's Avatar
CJ1957
Your tire to fender clearance looks a bit high on both front and rear.
In your profile under mods, you say you have C6 Z06 Wheels with 325 30 19 and 275 35 18 and I'm assuming that's back to front.
My questions are is the height set so that they do not rub under heavy lateral swaying and are these oem spyder's?
Let us know please. Thanks
Old Nov 16, 2019 | 10:01 AM
Nyt_Muves's Avatar
Nyt_Muves
The suspension adjustments and parts are all OEM stock. Z71 handling package and upgraded to C6ZO6 shocks but nothing else different. I have had no rubbing issues.
To Wheel offsets C5 to C6
