ignition
Old Jul 3, 2017 | 04:44 PM
yeraldoVette97's Avatar
yeraldoVette97
5th Gear
Default ignition
hi my corvette yet in the rain and not start
Old Jul 3, 2017 | 04:46 PM
yeraldoVette97
5th Gear
hi friend, can you help me?
Old Jul 3, 2017 | 04:53 PM
'Shifter's Avatar
'Shifter
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
First mistake: Vette....rain....everyone knows they melt in the rain...
Old Jul 3, 2017 | 05:10 PM
001pewter's Avatar
001pewter
St.. Jude Donor '17-'18
Some more info may help. What's it doing? What have you tried? Have you checked the codes? Google how to check c5 codes.
Old Jul 3, 2017 | 05:12 PM
knewblewkorvette's Avatar
knewblewkorvette
Not much to go on.
Weak battery? Get a jump?
Old Jul 3, 2017 | 05:23 PM
001pewter's Avatar
001pewter
Old Jul 3, 2017 | 06:26 PM
JR-01's Avatar
JR-01
Does it crank over and not fire? Or does it do nothing when you turn the key? More info, please.
Pull the codes and post them
Old Jul 3, 2017 | 06:29 PM
yeraldoVette97
5th Gear
only wet the BCM, Fuse box and not start. i checked all fuses and are o.k..
Old Jul 3, 2017 | 06:31 PM
JR-01's Avatar
JR-01
Good Luck.
Old Jul 3, 2017 | 06:38 PM
yeraldoVette97
5th Gear
the BCM wet and box fuses, i checked the fuses all are o.k.
Old Jul 3, 2017 | 06:50 PM
001pewter's Avatar
001pewter
Ok if the bcm is wet it's not gonna crank until dry. You need to clean the udders also. Search the forum for cleaning c5 udders.
To ignition
