New Toy Installed
MSgtrock (07-04-2017)
moncal90 (07-05-2017)
Received 19,607 Likes
'20-'21-'22-'23-'24
Sweet addition to your garage.
Received 4,522 Likes
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Sweet
1/4 mile/AutoX
Thanks all for the nice compliments! I've been wanting one for awhile now and finally got the garage door redone so that it lifts high enough so I can fit the lift in. I already changed out the oil in the Vette this weekend. Omg so much easier.
Patches.. I wouldn't have it any other way. Bolting it down is much safer and was a piece of cake.
4 post lift
DN69427.. I went with the Bendpak HD-9 220V... my ceiling height is 128" and I had the garage door redone so it lifts to where it's only 4-5" off the ceiling which gives me a good 120" of room. This lift will fit in your garage with that height but you wouldn't be able to lift a car to the full height. Here's the specs of my lift...
Lifting capacity*: 9,000 lbs. / 4,082 kg
*Max capacity / front axle: 4,500 lbs. / 2,041 kg
*Max capacity / rear axle: 4,500 lbs. / 2,041 kg
Overall width: 110‐1/4” / 2,800 mm.
Outside length: 174" / 4,420 mm
Overall length: 200" / 5,080 mm
Height of columns: 88" / 2,235 mm
Runway min height: 4-1/2" / 114 mm
Max rise: 70" / 1,778 mm
Max lifting height: 74-1/2" / 1,892 mm
Width between posts: 100‐1/4” / 2,555 mm.
Runway width: 19" / 483 mm
Width between runways: 37-1/2" - 44-3/8" / 952 - 1,127 mm
Length of runways: 164" / 4,166 mm
Min. wheelbase @ rated capacity: 115" / 2,921 mm
Min. wheelbase @ 75% capacity: 100" / 2,540 mm
Min. wheelbase @ 50% capacity: 85" / 2,159 mm
Min. wheelbase @ 25% capacity: 70" / 1,778 mm
Locking positions: 12
Lock spacing: every 4" / 102 mm
Lifting time: 45 sec
Motor: 220 VAC / 60 Hz / 1 Ph
Mickeyrx70 (07-05-2017)
Cool addition to your garage. I wish I had been farsighted enough to have designed my garage to accommodate a lift when we built our house.
thank you so much for the info - I have been looking at ways to "tray" the ceiling in my garage to give me some extra head room - but happy to know I can still get one to fit.
