C5 harmonic balancer
Old Jul 15, 2017 | 02:02 AM
Nyt_Muves's Avatar
Nyt_Muves
Originally Posted by JohnRogers
I'm looking through YouTube now. Any recommendations on a video showing what a bad harmonic balancer looks and sounds like?
Mine was easy to tell. The whole outter ring shifted back against the timing cover and oil pan and only 3 ribs of the belt were still making contact with the balancer pully.
Old Jul 16, 2017 | 10:41 AM
MrGary2011's Avatar
MrGary2011
Default Whatever
On my 98 the balancer went out at 140,000 miles. I can live with that. GM put a new one in and zero issues a year later!
Old Jul 16, 2017 | 10:45 AM
MrGary2011's Avatar
MrGary2011
Originally Posted by deejbee
OP, my balancer has been wobbling since I bought the car about a year ago.
I got a shop that specializes in LS cars and Corvettes to give an estimate to replace it - I supply the balancer, bolt and new belts, and they quoted me $516 CAD to do the job.
That comes out to about $410 USD.
I have been driving it with the chirp and the wobble but it is always in the back of my mind that I could pay a heavy price if something goes south.... will be getting it fixed within the next month probably.
Try Gator Belt, might eliminate the noise. If it is the balancer get it fixed! Mine actually slipped a 1/2 inch forward (the balancer is made of 2 parts and the outer hub just moved out), next thing I knew the belt came off the tracks. I was lucky happened right in the garage!
Old Aug 26, 2021 | 07:53 PM
Adam215's Avatar
Adam215
7th Gear
Originally Posted by ArmchairArchitect
Are you in a low, medium, or high cost of living area?
The lowest quote I got was for $360 in labor if I supply the part, this was from a Corvette specialist who does work on the side. This is in a medium cost of living area. Most other quotes I got were for around $500 in labor (I supply the part).
FYI here are other things to do at the same time as the balancer since the parts are cheap and labor will be pretty much the same while already in there:
Replace steering rack bushings while at it, since steering rack needs to be dropped. Also to pin the balancer to the crank, and use an ARP bolt with red loctite. Also replace front crankshaft seal as part of job. And possibly the ball joint boots. Most of these parts you can find cheap on RockAuto (or try GMPartsDirect.co).
The Dayco Powerbond balancer seems to be popular on this forum, and only costs $63 +shipping via RockAuto. Whatever you do, don't put an OEM GM one back in as they have a design flaw and will fail again.
I really appreciate the list of other stuff to do while you're in there. This post is a couple years old, but any chance that Corvette specialist you mentioned is still working in the area? I think I need to replace my harmonic balancer, and it's just not in the cards to DIY right now so I'd really like to talk to someone trustworthy.
