Sound system upgrade?
Old Jul 25, 2017 | 06:13 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Originally Posted by laserjack
Well said !... I've thought about upgrading my system also, and Dennis provides a world of knowledge and suggestions.
IM only trying to help the OP. But had to defend my reputation when someone post my name and then makes false statements about me..
The nice thing about Dennis is he is a corvette guy... he has morals and ethics.. something very rare today. He tweaked my research and made my system better . He built my system and made it plug and play. Upgraded head unit, rear camera and sounds system. I just had to take out old parts speakers etc. and plug in New ones. Easy peasy.
Not everyone is willing to spend 3 or 4 grand on an upgraded system. Dennis can offer a system under 1K and over 3 K. The first thing I said to the OP was have a budget in mind.. with that Dennis can provide the best system within that budget, he will also offer a system one step below your budget, and one step above so you can see some options.
Just trying to help the OP
My system under 1K head unit and upgraded speakers.
Old Jul 26, 2017 | 03:28 PM
RVETTE42's Avatar
RVETTE42
Originally Posted by GCG
It might be that your door-mounted subwoofers are not working. You have 1 subwoofer with a built-in amp in each door. If both of them stopped working at the same time it's possible they are not receiving power. Check fuse 28 and micro-relay 45 in the passenger fuse box.
I was thinking it could be your woofers also. I have a complete custom audio system from Double D so I would also recommend him for help with current system or new system.
Old Jul 26, 2017 | 05:25 PM
mrmagloo's Avatar
mrmagloo
I will mention that I happen to be one of those guys who likes the stock look. Nothing wrong with those who choose to go with a more modern touch screen head unit, but there are other options.
I found that the stock Bose system can sound alot better by simply replacing the front tweeters, and adding new Coax Speakers in the rear. Then I went with a iSimple 30-pin iPod kit, which I can swap out for a Coolstream BT receiver.
The speaker swap made a tremendous improvement. Also, while the AM/FM will probably never sound great, with a CD, iPod, or Spotify over BT, the sound is as good as any more modern OEM radios.
For everything from Dennis, JL C2 350x/525x and iPod kit, it came to less than $300. That was a bargain.
Old Jul 28, 2017 | 12:14 AM
Evil-Twin's Avatar
Evil-Twin
Originally Posted by LoneStarLizzard
Bill, I said that very tongue-in-cheek, intending it to be very high praise for your competence.
Obviously you didn't enjoy my attempt at humor.
The Lizzard
I apologize... I took it the wrong way,, I offer no excuses for my bad taste here. .I take full ownership for my short comings. Unfortunately, because I take very aggressive cancer meds... they are actually poisons.. and they are experimental, ( Clinical trials )they sometime cause very intense mood swings.. Again I apologize.
Bill aka ET
Old Jul 28, 2017 | 12:55 AM
SAYUNCL's Avatar
SAYUNCL
Bill aka ET
deep respect
Old Jul 28, 2017 | 08:04 AM
LoneStarLizzard's Avatar
LoneStarLizzard
Bill aka ET
An apology was entirely unnecessary, and very graceful on your part. I just buried my 92-year-old Dad in May (liver cancer), so I fully understand that one's priorities change when health issues arise.
Keep commenting on the Forum. Your perspectives on "why did Chevrolet do what they did" and similar bits of the C5's history are fascinating stuff.
As a next topic, why don't you address why the ABMS modules in both the earlier and later year C5s are so problematic. I suspect some bean-counters put their fingers on the cost-vs.-quality scales when these modules were designed and made. Your insights would be interesting.
I learned yesterday that plastics used in the manufacture of later year C6 starters/solenoids melt due to the heat emanating from engine exhaust manifolds. No doubt that defect is just a more current example of the same cost-trumps-quality mindset. [I can predict where you stand on this - quality always trumps cost.]
Keep it up Bill. We're in your corner.
John (age 68) aka the Lone Star Lizzard
Old Aug 1, 2017 | 07:21 AM
CPO Rob's Avatar
CPO Rob
Veteran: Coast Guard
Default ME Too
Originally Posted by JimHarris4
Just took a 1200 mile ride this weekend in my relatively new (to me) '98 vert. The sound was way too tinny, like an AM radio. Is it a bad/blown sub?
If I upgrade my sound system, do I need to do both head unit and speakers? Or would sound insulation dramatically improve it?
Any audio brands to avoid?
Thanks in advance. And keep driving!
I also have a C5 that I want to retrofit with a GPS/Audio and backup cam. I have looked a many different ones and this is the one that DD and many other high end installers recommend. Yes it is pricy, but there are others in the line that can make that difference for you.
https://www.pioneer.com.au/shop/car/avh-x8850bt/
https://youtu.be/id2EQHcxKpA
My feeling is, if you have a high end car, put the good stuff in here
CPO
Old Aug 1, 2017 | 08:43 AM
GCG's Avatar
GCG
...The sound was way too tinny, like an AM radio. Is it a bad/blown sub?...
Thanks. Exactly what I was looking for. I thought something must be loose or blown. The sound is awful.
Much appreciated!
Just out of curiosity, were you able to check the fuse and micro-relay?
Old Aug 1, 2017 | 04:33 PM
Evil-Twin's Avatar
Evil-Twin
Ive given the very long answer a few times in 16 years here.. Ill try the shorter version.
We get about two years to design a car, from conception to launch. There are 6,000 parts in a C5. The platform is separated into modules.
Each module has a Project manager and a team of design engineers. Its the project manager's job to keep all of the design components of his module within budget and on time. Many components are built via 2nd tier manufacturers. All have GM engineering oversight. It's very hard to design a car in a two year time frame and debug everything before launch. About 30 years ago American car manufacturers went to the Japanese method of field debugging in an effort to get a new car to market faster, bringing the 4 year concept to design frame down to two years. Allow the public to identify problems in the field and then fix them. Things that fail outside of the warranty period are unforeseen.. All components go through something called an FMEA ( failure modes effect analysis ) where we try to foresee and failures before the final design , the design gets a score and is tweaked for final design approval. Unforeseen issues are the reason these cars are not perfect.. Time and budget play the biggest part. If they were more perfect, most of us would not be able to afford them In 1997 you got a whole lots of car for 45/50K . some new innovations not available or any other car in this price range.
Consider that these cars are seeing 20 years very gracefully. typically that wasn't the case 30 years ago. from other manufacturers. American car in the 50's and 60's were trash after 60,000 miles.. a bench mark to sell your car before it hit 60K.. today many C5's are seeing 300K and 400K without any internal motor repair.
The Short end.
Bill aka ET
I know a few things because I have seen a few things.
Old Aug 3, 2017 | 12:50 AM
striper's Avatar
striper
CPO
I purchased a Kenwood Excelon DD radio from Dennis with all the features you are looking for, plus more including bluetooth, too. It sounds fairly good using the stock speakers but if I had the time and money I'd upgrade the system. It hasn't been a priority because I have several other projects, plus other more important mods I still haven't done to my car. If you're not too picky just replacing the radio with the features you want will make you very happy while modernizing your car. His prices and phone assistance was excellent when I got stuck installing everything.
Old Aug 3, 2017 | 04:35 AM
CPO Rob's Avatar
CPO Rob
thanks Striper.. Was that the Kenwood Excelon DDX794? I am somewhat leery about this android phone thing with the component. I mean what happens in 5 years when the phones change, will the component work? Also how did the Backup cam work
Old Aug 3, 2017 | 08:07 AM
LoneStarLizzard
The Short end.
Bill aka ET
Thanks Bill. From my perspective, Chevrolet has always looked to its Corvette platform as the launching pad for innovation. With that innovation comes the inevitable teething process.
As they say, pioneers get the land. Of course, they also get the arrows.
Lucky for us later-year C5 owners that enthusiasts have developed a fix for our ABMS modules.
The Lizzard
