Horn help...?
Old Jul 24, 2017 | 10:27 PM
IrishViking505's Avatar
IrishViking505
C5 of Month Finalist 2017
Default Horn help...?
So, for some reason, the horn assembly was missing on my 2004 when I bought it. While driving home I attempted to honk at a jacked-up truck who was about to change lanes right over me...and nothing.
When I got home, I inspected under the hood and could not see/find a horn assembly.
**As a reminder, I am completely new to the Corvette world, but not to Chevys.
I did find an empty plug up in the passenger side front area near the radiator/light area. I am guessing this is where the horn assembly would plug in?
I just bought a horn assembly...
-Wondering if someone could verify this location for me?
-Perhaps, provide a photo of where the horns are and mount?
-AND, I am in need of the wire connector that joins from the horn assembly to where it plugs into the main harness. Part #?
Thank you!
Liam
Old Jul 25, 2017 | 06:24 PM
IrishViking505
sweet!
I will check it out and see what's what!
Old Jul 25, 2017 | 06:27 PM
redzg's Avatar
redzg
And the empty connector is probably for the ambient air temperature sensor. Any chance your HVAC control is reading a constant 69°? Or to dim to see?
Old Jul 25, 2017 | 09:38 PM
IrishViking505
Originally Posted by 8VETTE7
Might also be the underhood light connector. That is also up there in the same area. If underhood light does not illuminate with the hood open then it is most likely the purpose of the connector...........
I guess that could be that...there is no underhood light or wire.
Old Jul 25, 2017 | 10:38 PM
IrishViking505
Default Horn Relay!
Okay, so thank you all for your assistance!
I was able to actually see the horns front the front of the car with the hood open...reached in and felt they were there and plugged in.
Next, I made sure the alarm was set to lights and horn for both the alarm and arming. When I tested by pressing the horn on the steering wheel - nothing. When I tested with the alarm remote - nothing.
I took a twilight ride down to the local O'Reilly's and picked up a fuse relay part # R3115. Popped it in and the HORNS NOW WORK!
Alrighty then!
Thank you all for your help and inputs!
I am still curious as to what that empty plug is...I will snap a photo later and post it.
Thank again all!
Liam
Old Aug 4, 2017 | 10:47 PM
IrishViking505
That is it...
The previous owner has all kinds of engine dress-up stuff in the bay...must have removed the light.
Thanks for the pic. Now I know.
Liam
To Horn help...?
