I recently acquired a set of NOS speedline SL173 front wheels still in the factory plastic. was wondering what the value of the wheels would be
has a casting number 9594808 on the back but the box says 9595433
I didn't catch that you only had the fronts.
You will likely only be able to sell them to someone who needs a replacement wheel due to damage.
The rears carry more value because C5 people like to add a second set of rear size wheels to the front in order to fit wider tiers.
I would put them on the auction site individually for ~$125 bucks each with a long duration listing. Probably your best bet to move them as posting here or locally on Craigslist they will sit for quite some time until the right buyer stumbles upon them.
GLWS
Plenty also use them for rears with DOT slicks due to their being light, available, and relatively cheap.
