Poltergeist in my wipers?
Old Jul 27, 2017 | 09:41 PM
C5 Newb's Avatar
C5 Newb
Default Poltergeist in my wipers?
Had a doctors appointment today in Phoenix and as I am heading home to Payson I had an issue I am not sure what it is.
Sunny day about 1,000 degrees outside cruising down the highway and for no reason the wipers started and ran intermittently like on the lowest setting. I would turn the switch on and off and run through the intermittent setting and finally it would stop.....then a few minutes later it would start again. I thought I was going to have to pull the wiper fuse.
I couldn't find anything in the search feature about this, anyone have a clue?? PLEASE......feel free to chime in.
Is it the switch most likely?
Old Jul 27, 2017 | 10:06 PM
If you've had rain recently, check to make sure your wiper motor did not get water inside - could be plugged udders.
If no rain, could be the multifunction switch on the steering column.
Read the attached file.
File Type: doc
Old Jul 28, 2017 | 12:14 AM
C5 Newb's Avatar
C5 Newb
Thanks man for the help, sounds like the second one you posted, I did just wash the car today a couple hours before it started. I will clean out all those drains and hopefully that will fix it.
Your awesome!
To Poltergeist in my wipers?
