2000 Coupe Question
Old Aug 6, 2017 | 03:00 PM
dcar11's Avatar
dcar11
2nd Gear
Default 2000 Coupe Question
I have a 2000 coup. The ecl is on and showing a p1860 code. I had a transmission shop check out the transmission. they dropped the pan , said the fluid looked like new, no debris , the changed the tcc solenoid. test drove it and still getting the code. Do you think it could be the PCM. Thanks
Old Aug 7, 2017 | 10:52 AM
dcar11's Avatar
dcar11
2nd Gear
Ok thanks , I did just recently change the battery and noticed what look like a previous acid leak from the battery. will investigate further.
Old Aug 7, 2017 | 12:44 PM
001pewter's Avatar
001pewter
St.. Jude Donor '17-'18
Removing the inner fender will give a good view on other places the acid may have got to also.
Old Oct 11, 2020 | 11:35 AM
KEARNEYN's Avatar
KEARNEYN
Did you find the solution to this problem?
Old Oct 11, 2020 | 12:25 PM
robert3elizondo's Avatar
robert3elizondo
The post is 3 years old and no sign of the OP returning to reply to your post.
To 2000 Coupe Question
