outside temp
Old Aug 7, 2017 | 09:12 PM
namvet6869's Avatar
namvet6869
Default outside temp
Cleaned engine area today. Sprayed some water. Now outside air temp is about 40 degrees off. Will that correct itself after a while. Anyway, where is sensor located?
Old Aug 7, 2017 | 09:31 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
lower right bottom of radiator !! (front)
Old Aug 7, 2017 | 10:09 PM
Forcedvert's Avatar
Forcedvert
Once everything is dry it should read correctly, wet sensor will read whatever whet bulb temp is outside (cooler in dryer air) I would think this would not take long to dry, atleast not here. So my answer is a firm maybe
Btw
That difference is too high for just a wet sensor (wet bulb reading), it may still correct itself if a connector got wet and is effecting the resistance reading. Still a maybe
Old Aug 7, 2017 | 11:31 PM
Hopefully all it is is the sensor got wet. If not, easy replacement and inexpensive part.
Old Aug 8, 2017 | 12:09 AM
CJ1957's Avatar
CJ1957
Amazon Amazon
Old Aug 8, 2017 | 08:06 PM
jrprich's Avatar
jrprich
Or for 50% less ;^)
Amazon Amazon
Old Aug 8, 2017 | 08:42 PM
namvet6869's Avatar
namvet6869
Thanks for the replies. Got in this morning and things were back to normal.
Old Aug 9, 2017 | 05:58 PM
namvet6869's Avatar
namvet6869
[QUOTE=namvet6869;1595320677]Thanks for the replies. Got in this morning and things were back to normal.[/
Spoke too soon. It on the blink again
To outside temp
