Lower...Raise...Level...?
Old Aug 16, 2017 | 10:54 PM
IrishViking505's Avatar
IrishViking505
C5 of Month Finalist 2017
Originally Posted by TorchRedLS6
Greetings from Rio Rancho. Great looking C5, BTW.
Thanks!
Ever get over to SF?
Are you part of a club?
Liam
Old Aug 16, 2017 | 11:26 PM
sunvet's Avatar
sunvet
Until recently I had my C5 lowered quite a bit. I even got the longer lowering bolts for the rear. But over the years I noticed the harshness in the rear because of lack of travel in the suspension. So I just now went back to the standard bolts and raised the car back up just over an inch in the rear. Much better ride now, and no noticeable difference in handling. Doesn't look as cool though! I will also be raising the front back up a bit, too.
Old Aug 17, 2017 | 12:12 AM
Verrückt ZR1's Avatar
Verrückt ZR1
Originally Posted by IrishViking505
Thanks!
Liam
We head up there for lunch or shopping every now and then. The only club I know of meets at Reliable Chevrolet in Albuquerque. First Sunday of every month, I believe? Ha. Always meant to check it out, but you know how that goes.
Welcome, and get that thing raised a bit! These NM driveways are nightmarish.
Old Aug 17, 2017 | 01:56 PM
03WhiteConv's Avatar
03WhiteConv
Originally Posted by cdg2000c5
It's when the diameter of the front wheel/tire increases exponentially compared to the rear, and you loose the factory stagger effect.. that's what tends to cause TC issues
It really doesn't take much of a change, many threads here talking about this issue. I know when I bought my tires, because I was changing sizes, I did a lot of searching to make sure I didn't screw it up.
Bill Dearborn has a great, concise explanation of how to calculate the rake based in the tire size https://www.corvetteforum.com/forums...post1595124165
It really is about not confusing the pitch and yaw sensors etc. If you change the attitude of the car by leveling or raising/lowering one end too much more than the other the calculations are off and the car can't figure out what the driver is doing.
Causes TC light to come on and ABS to fire at weird times like in a turn when it shouldn't. Pretty dangerous. Sometimes happens when people slam their cars so low like they do without maintaining a little butt in the air attitude.
Old Aug 17, 2017 | 02:02 PM
03WhiteConv
Originally Posted by MrLeadFoot
I changed the rake in mine a bit, but I didn't have any such issue.
Yeah, not too sure how far off it has to be for the problems to show up. When I first got my car I had a brand new set of stock GY runflats. Wasn't too long before I realized how bad they were. But then I learned how expensive new shoes were too. Love the Conti choice for a DD and the sizes worked great too. Just couldn't afford to drop a grand on a mistake so I maintained the rake as close as I could after reading all of the problems people were having.
Old Aug 17, 2017 | 03:21 PM
IrishViking505
They are...lucky for me, every single one of my cars I have ever owned with the exception of two trucks, were low-riders....
Old Aug 17, 2017 | 03:24 PM
IrishViking505
where are these "lowering bolts" located?
Old Aug 17, 2017 | 03:36 PM
runner140*'s Avatar
runner140*
Looking for a link or post on how to lower/raise or level out a C5...that also has illustrations.
I have a 2004...new to me and me new to it.
I have no clue if it has been lowered or not. If it has, I would like to raise the front about 1/2"
Thank you
Liam
Take a look at YouTube and search C5 Corvette lower on stock bolts.
Old Aug 17, 2017 | 04:58 PM
peteinpa's Avatar
peteinpa
I had my car lowered on stock bolts last year and I am running stock tire sizes. I do throw a Code for TCS/ABS every so often I believe it is C1271.
To me the car looks almost level, not much of a rake at all. I am starting to wonder if this is a possible cause for the TCS/ABS lights coming on and maybe I should raise the rear?
Old Aug 17, 2017 | 05:56 PM
tcruse's Avatar
tcruse
Lol I just bought a house in Rio Rancho and I find myself one wheeling to get in my drive way.
Old Aug 17, 2017 | 06:07 PM
Verrückt ZR1
Nice. You've got the technique mastered, no doubt. You might consider having the wheels balanced after adjusting the lowering bolts. Some say yes, others no. I figure it's always best to be on the safe side. No sense trashing expensive tires on anything but burnouts.
Old Aug 17, 2017 | 06:09 PM
Verrückt ZR1
I hear ya. RR has some nasty entry curbs and inclines. I've been looking at ZR1's and have gone back and forth a hundred times if the car would make it up the driveway in one piece.
Old Aug 17, 2017 | 06:22 PM
  #33
MrLeadFoot's Avatar
MrLeadFoot
No, no, no. You want an ALIGNMENT, not a tire balance, after changing height.
Old Aug 17, 2017 | 07:17 PM
  #34
Verrückt ZR1
Correct. Alignment. Ha. Thursday blues?
Old Aug 18, 2017 | 04:14 PM
  #35
IrishViking505
Doesn't matter - It's Friday now!
