First gear problems.
Aug 12, 2017 | 08:42 PM
2002 Z06
spec clutch
aluminum flywheel
tick master.
Last few days my car had been jumping and some time grinding shifting from neutral to first from a stop about 20 percent of the time.
I bleed the master and adjusted the pedal some more and it seemed to get worse.
Any input?
Aug 12, 2017 | 09:28 PM
Common problem with these cars/transmission. My car does it too. I just shift to 2nd then back to 1st. Seems to work 95% of the time.
Aug 13, 2017 | 10:51 AM
uggg i hate t56's
i figured it might be a hydraulic problem.
i may try a swap to syncromesh fluid
i replaced the main shaft and 5th gear and syncro last year and everything else looked in good shape.
Aug 13, 2017 | 12:23 PM
my clutch used to rattle at idle with the light flywheel.
Now it seems to be gone, i wounder if my pilot bearing is the issue.
Aug 14, 2017 | 05:27 PM
When is the last time you did a shifter alignment? It is worth trying as it doesn't cost anything but time.
Aug 14, 2017 | 07:19 PM
That's my next step.
I have it on jack stands now and the wheels are not spinning with clutch in and first gear.
If i go to second first its fine!
Aug 14, 2017 | 07:36 PM
St.. Jude Donor '17-'18
Aug 14, 2017 | 08:33 PM
Finally noticed when going into first it spins rear tires like half a revolution.
still ok from second. so it may be a clutch problem.
