HID Foglamp kit
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
ACA headlight units modified by RadioFlyer to align high beams correctly. HID low beams, HIR high beams, HID fog lights. Plus the Hi-4 harness and a DIY harness to keep fogs on with high and low beams (may be illegal in most states and caution must be used to avoid blinding oncoming traffic). Also LED strip corner lights from RadioFlyer with LED DRL's.
thunder1951 (08-17-2017)
Received 1,679 Likes
Agreed, but until I upgrade to projectors for the high beams, the HIR's came closest to matching. If they were on by themselves they are actually very bright. It is only when they are on with the rest that the comparison is evident. Maybe this winter for the upgrade.
Oldtimer
Daniel Stern does not like fog lights because he feels it causes drivers to look more at the bright road directly in front of the car instead of 'down the road' which all regular headlights are designed for.
They are indeed projectors but the design of the lens, being that they are true fog lights and not driving lights, is such that the light becomes more diffused than penetrating down the road (in fog, you almost have to drive with peripheral vision!). That's why most people don't realize the C5 fogs are projectors.
#34
Yes, it's kind of tough to know what to get initially because technically, the 6500k - 7100k range is white. BUT, when projected from a car, even that temp range shines blue. 8000 degrees kelvin would surely be very blue. 4300k is technically more yellow, but when projecting from headlights, you see pure white. When people see me coming with my 4300k bulbs, they see white headlights, not "look-at-my-mod" blue!
#35
Oldtimer
#37
HOLY MOLY!! I just found that I bought these radioflyer fog kit. Gotta Love Chemo Brain!! Like Christmas every time I open a box in the garage. Last week I remembered I installed radioflyer Halos....
#38
I keep hesitating on buying the halo rears, but they just look so good. I just need to pull the trigger and buy them at some point.
