double din install help
Old Aug 24, 2017 | 07:29 PM
Stroker87's Avatar
Stroker87
Default double din install help
im going to install a double din radio only had time to rip it part so now i need to cut out the metal peace that runs horizontal like a shelf so whats the simplest way to do this? grind down the rivets or?
thanks!
Old Aug 25, 2017 | 01:28 AM
CactusCat's Avatar
CactusCat
I think most people use a 90 degree attachment on a drill and drill out the rivets, however, when I did my DD install, I took some old towels and stuffed them up under the dash (to catch any sparks or metal) and then I used a dremel tool with a cutting blade to grind the rivets off. Didn't take very long at all. Be sure to use ear and eye protection if you do it this way.
GL...
Old Aug 25, 2017 | 09:03 AM
joezr2's Avatar
joezr2
I used a sawzall..... seriously... blade right between the bracket and the side wall whereit is attached. It keeps the blade from moving around and goes right through the rivits leaving a smooth cut on the side. It looked terrifying to stick a sawzall in my dash (to my wife) but it was really easy, and with everything already out of the way I wasn't going to accidentally hit anything anyway. Sticking some sort of towel in there is a good idea. It catches all of the shavings and covers anything from accidentally getting nicked. Used a finer, metal blade and it took all of 5 minutes to get it out of there.
Old Aug 25, 2017 | 03:24 PM
Stroker87's Avatar
Stroker87
thanks guys!
i use my dremal with a cut off wheel, i did look at my sawzall but just couldn't us it lol
Old Aug 27, 2017 | 07:44 AM
BRAVO1's Avatar
BRAVO1
VETERAN
I agree........
To double din install help
