Noisy interior panels
Old Aug 25, 2017 | 09:46 AM
Bob in Elliot Lake's Avatar
Bob in Elliot Lake
Default Noisy interior panels
Bought my 2000 Base Coupe last October, 30,000 miles, seems like it had been very well looked after. Anyway, had small creaking noises occasionally from where interior panels meet, annoying on rougher roads, but not too bad. It recently, last week or two, got much worse. Drove me crazy. Last night I went through it all, made sure nothing was loose, didn't find a problem. So I just hit the spots where interior panels meet, mainly around the halo, with silicone spray lube. Made sure to get the spots where the fasteners are. Five minutes into a ride afterwards, and it now doesn't just "look" new, it sounds new as well. Well worth the small effort.
Old Aug 25, 2017 | 09:59 AM
Hopefully it keeps the panels from making noise for a while. I can understand how annoying a bunch of creaks and rattles can be in a vehicle.
Old Aug 25, 2017 | 10:33 AM
Bob in Elliot Lake
I really now just think age has "dried" and maybe "deformed" the interior panels a bit, unnoticeable to the eye. I can live with lubing the mating areas and fasteners once in a while. We'll see. How often it has to be done will determine my next move. If necessary, I suppose I could replace the fasteners, but if I can just lube it, even once or twice a year, I think I'll stick with that
Old Aug 25, 2017 | 04:53 PM
The Rabbi's Avatar
The Rabbi
2018 C5 of Year Finalist
St. Jude Donor '14,'18
I hate interior noises too. Now I'll know what to do when it happens.
We used to say about rattles etc. just turn up the radio !!!
Old Aug 25, 2017 | 07:47 PM
SilverC54me's Avatar
SilverC54me
Get some .5 inch wide felt rolls with an adhesive backing. Put this on one side of where the panels come together. This will stop the plastic to plastic noise.
Clean up any of the lubricants you used since these can and will run down the panels and cause discoloration. Depending on the lubricant it may also dissolve the plastic.
You can get the felt rolls on Amazon for about $10 to $15.
Gary
Old Aug 25, 2017 | 08:32 PM
Bob in Elliot Lake
Thanks for the heads up Gary. Did this yesterday, and I've been keeping an eye for any sign of seeping out, nothing yet. I sprayed a piece of an old plastic dash panel from another car before I sprayed it in my vette, it just seemed to soak in sort of and felt kind of wax like. Got some on my hand, slippery as hell. Silicone spray lube is supposed to be safe for just about anything I believe, but on your advice I will at a minimum keep a very close eye on it for long enough to be sure it doesn't cause damage. If I had thought of it I probably would have done as you've suggested instead.
Old Aug 26, 2017 | 07:40 AM
Mickeyrx70's Avatar
Mickeyrx70
Thanks for the tip ... I've got a squeak on the passenger side coming from the plastic door frame molding ( I think). I'll try silicon lub on it.
Old Aug 26, 2017 | 01:24 PM
SilverC54me
Use the felt pieces I mentioned earlier in this thread. It will last longer and won't discolor the plastic.
Gary
To Noisy interior panels
