A C frustration
Old Aug 27, 2017 | 09:20 AM
BRKLYN's Avatar
BRKLYN
Default A C frustration
Help! Cold ac under the hood, hot inside. Is there a quick fix? I read about doors. I had a 69 Grand Prix this happened once,turned out to be vacuum line slipped off or was pride off,while under the hood. Do we have a vacuum line? I ride a lot with Targa off,but would like option for ac, especially with my lady in the car.
Old Aug 27, 2017 | 03:21 PM
001pewter's Avatar
001pewter
St.. Jude Donor '17-'18
Underhood? Yeah theres a vacuum canister and lines that control the vent settings, cold ac on the pass side vent and hot on driver side means low freon.
Old Aug 31, 2017 | 05:27 PM
BRKLYN's Avatar
BRKLYN
I will search for the canister and evaluate the hose.
Old Aug 31, 2017 | 05:35 PM
001pewter's Avatar
001pewter
The canister is in the passenger side fender well. Behind the pcm, with the door open you can see the the side of it and 2 mounting screws.
Old Aug 31, 2017 | 05:37 PM
001pewter's Avatar
001pewter
The vacuum controls the different settings, defrost, feet, face
Old Aug 31, 2017 | 08:31 PM
jjc508520's Avatar
jjc508520
I am in the same boat - I can grab the tubes that run along the firewall and they are cold - but nothing going on inside...
Old Aug 31, 2017 | 09:09 PM
001pewter's Avatar
001pewter
So thats what cold underhood stood for, didn't know that. Does the a.c. have any codes? I think if there's a problem with the doors it throws a code.
Old Sep 1, 2017 | 12:46 PM
unlvrebel's Avatar
unlvrebel
The answers you seek are here.
Old Sep 1, 2017 | 01:29 PM
001pewter's Avatar
001pewter
My ac is fine, I repaired the canister, Schrader, and slapped some freon in it. Op has ac problems.
Old Sep 1, 2017 | 06:14 PM
BRKLYN's Avatar
BRKLYN
Mine goes where I set it. I'm getting hot air, on the other side firew all under the hood,it freezing cold.
Old Sep 1, 2017 | 08:25 PM
001pewter's Avatar
001pewter
Oh, I didn't understand then, I never had that problem so I've really got no help. Maybe someone else will chime in that's experienced it.
To A C frustration
