Radio/Aux Input Question?
Old Aug 29, 2017 | 11:30 AM
Squeaky Wheel's Avatar
Squeaky Wheel
Default Radio/Aux Input Question?
Hi folks. I'm a former C5 owner now driving a C7 coupe. Always enjoyed my C5 (which was also a coupe) but wished it had an iPod input. Would now like to buy an additional C5 convertible if there is some way to add the iPod input to the factory audio system. Is that possible? Any suggestions? If not, I'll be searching for an 08 or later C6 convertible. Want to keep everything pretty much stock, so not interested in an after market stereo.
Old Aug 29, 2017 | 11:35 AM
glbeauchamp's Avatar
glbeauchamp
Check with Dennis at DoubleD Mods. He's a forum vendor. I bought just what you are looking for, I believe, for my C5. 608-854-2033
Old Aug 29, 2017 | 12:01 PM
ArtClassShank's Avatar
ArtClassShank
It can be done, about $60-$70 and roughly 30 minutes of your time. Less time if your car has the optional 12 disc changer. You just hit the CD/Aux button twice and boom, you're playing aux through your speakers.
Old Aug 29, 2017 | 12:55 PM
Squeaky Wheel
Could you offer some details? How?
Old Aug 29, 2017 | 01:46 PM
Whiteonrice's Avatar
Whiteonrice
http://www.discountcarstereo.com/AUX-GM2.html
One option I found.
Old Aug 29, 2017 | 01:50 PM
GCG's Avatar
GCG
You may want to explore the option of adding an Aux input for around $3.
Old Aug 29, 2017 | 02:07 PM
ArtClassShank
This is the kit I purchased.
Amazon Amazon
Very simple to install, if you can assemble a dresser from Ikea, you can do this. Much easier!
Old Aug 29, 2017 | 03:41 PM
glbeauchamp
That's what I got from DoubleD. Installation was pretty easy and straightforward
Old Aug 29, 2017 | 03:53 PM
Squeaky Wheel
Thanks fellas. Good to hear that it is indeed possible. Back when I had my C5 I was told by 2 local car audio shops that it couldn't be done. Probably not a job I would be comfortable trying myself however. Fearful of messing up the dash or surrounding trim when removing the radio from the front panel. (Although I will continue to explore the procedure)
Old Aug 29, 2017 | 05:09 PM
glbeauchamp
There isn't really much to mess up as the console comes out before removing the radio. There 4 10mm nuts and maybe 6 Phillips screws holding the console if I remember correctly. Once that's out there isn't anything else left to mess up. Instructions on console removal are on You tube
Old Aug 29, 2017 | 05:18 PM
Squeaky Wheel
https://www.youtube.com/watch?v=WTbWYNJTSDs
Outstanding! Thank You.
Old Aug 29, 2017 | 05:23 PM
Stroker87's Avatar
Stroker87
its pretty straight forward, take your time and dont force any thing you'll be ok!
Old Aug 29, 2017 | 05:33 PM
Squeaky Wheel
I remember something about an anti-theft feature on the radio. Think that may be one of the reasons why the local audio shops said it couldn't be modded for an iPod input. Is there some security code or something that would need be recorded and reset? And if so, where would that be found?
Old Aug 29, 2017 | 06:58 PM
glbeauchamp
I don't recall having to do anything special when i installed my adaptor. But if there is an anti-theft thing, I imagine it would be in the owners manual.
Old Aug 30, 2017 | 08:30 PM
Borntorun04/17's Avatar
Borntorun04/17
I bought the above item in post 7 from Dennis at DOUBLE D MODS I had it in my 04 for over 5 years worked great with no problems. Install was easy with great directions. What I liked about adapter from Double D Mods was that you can still use radio controls While having IPhone hooked up such as ff, next, etc. I was able to have cable go into console storage area with out drilling any holes. Also charges phone while hooked up to adapter. The theft code as I remember didn't play a factor with adapter . Theft code was a pin you entered that if radio was stolen would not be able to unlock and use unless you had pin code. I had mine pin code set and adapter worked great.Dave
To Radio/Aux Input Question?
