run flat tires or not?
If you don't mind repairing a tire on the side of the highway in the evening then go for it. Michelin's by the way are not that much more then most non run-flats. Maybe around $200-350 total, which is not much more after loading your trunk with all of the repair kit stuff you need to buy and carry.
I believe most on this forum disagree with me on this subject, but you asked for opinions so that's what I gave you!
honda minivan 3 months ago
infinity sedan 2 years ago
other honda minivan last year
one of the reasons i go to BJs for my tires they fix them for free....
all of the flats were caused by screws
I have had a number of flats in those 17 years on my C5 (as I recall at least 5) - usually from roofing nails after hail storms. Two nails in one of my original GYRF tires. In every case I was able to get home and back in the garage or directly to Discount Tire to get the tire fixed or replaced.
Here are a couple photos of repairs on one tire back in 2006 - never had another problem with it...
I have had a number of flats in those 17 years on my C5 (as I recall at least 5) - tusually from roofing nails after hail storms. Two nails in one of my original GYRF tires. In every case I was able to get home and back in the garage or directly to Discount Tire to get the tire fixed or replaced.
My reasons are clear to me, first of all GM put run flats on these cars for a reason, second I can afford to buy them, third at the ripe old age of 75 I like the security they represent and I'm not physical enough to be wrestling with a flat on the side of the road, lastly, a Corvette is a sports car! If I was concerned with a smooth ride I would just drive a Cadillac!
Thanks for all the input guys , I really do appreciate it My reasons are clear to me, first of all GM put run flats on these cars for a reason, second I can afford to buy them, third at the ripe old age of 75 I like the security they represent and I'm not physical enough to be wrestling with a flat on the side of the road, lastly, a Corvette is a sports car! If I was concerned with a smooth ride I would just drive a Cadillac!
Thanks for all the input guys , I really do appreciate it As it turns out my car has almost new Michelin Pilot Sports, non run flats. So I'm thinking about the flat tire situation. I have owned a couple of Shelby Mustangs in the past few years and in the place where the spare goes they give you a molded foam block with a pump and a can of fix a flat or some such.
I think I'm going to buy one of those kits off of EBAY and go with that until it comes time to replace the tires. I never needed to use it with the Shelbys so hopefully I'll have the same luck with this car.
But from what i'm reading the new age run flat tires are more civilized than the older generation ones. If I didn't have almost new tires I would probably go that route. So this has been informative, thanks.
Thanks for all the input guys , I really do appreciate it What could anyone have said to make you consider non-runflats?
dan k.
Thanks for all the input guys , I really do appreciate it I think the main reason they went to the Run-Flats on the standard C5s from the factory is that the car was designed and aimed at the sports car "enthusiast" (like me) - that enjoys spirited driving, but still needs the practicality of a car focused to be drivable daily on the street. Run Flats opened up a ton of storage space AND added a much welcomed additional level of security for both the driver and the car - in fact the run flats were a major deciding factor for me when I purchased my C5 new in 2000.
The base C5 is not a race car (even though it can be easily transformed into that). The Z06 was more of a factory rendition of a C5 made track-ready, but still street legal - different audience. Most people buying a Z06 probably have no second thoughts about laying down on their back on the side of the road to fix a flat with traffic whizzing by.
In my case, Run Flats have been worth their weight in gold. I remember one instance where I had to get a package to Fed-Ex at the airport locally and was down to the wire before their closing time. It was for a client and it would have cost me thousands of dollars had I missed that deadline! Sure enough, while speeding there, up came the flat tire warning on the DIC - with my run flats, I still got the package there under the wire and limped home.
Another instance I have related here before when I got a call that my Mother had been rushed to the Emergency Room at the local hospital. On my way rushing to the hospital, of course one of the front tires went flat on the way there. Without run-flats I would not have made it to the hospital before she passed away. So needless to say, I am sold on run-flats for a DD C5. If I ever decide to go to the track or get into racing Mustangs at a traffic light, then I will buy the cheap-sticky-silent tires!
