Help with suspension set up.....
Old Aug 31, 2017 | 09:52 PM
EZ2BEVILC5's Avatar
EZ2BEVILC5
Default Help with suspension set up.....
Hello,
My so called high performance rear spring from VPB failed after only a few years. So I went back to stock C5 rear spring. Car sits low and is already into the agrressive part of the spring. The car handles great with no body roll. I'm wondering if I should go to the Z06 spring or will that be too stiff. I also have a set of the Urethane spring bushings. What do people think the best combination should be for the street for best handling?
Stock with Urethane bushings
Z06 with rubber bushings
Z06 with Urethane Bushings
Old Sep 1, 2017 | 09:43 AM
STALION's Avatar
STALION
From: ALL governments are legalized mobsters, so doesn't matter where I live :(
Depends on how aggressive you want it. I went from having the FE1 suspension and initially started with C6Z sway bars and performance in the corners improved, then went upgraded shocks from a C6Z and the ride became a little stiffer but nothing where you're breaking your teeth. Finally I installed C5Z springs with euro-bushings and never looked back! The car handles very well. I track mine often so I went this route. If you're primarily on the street you many not need the benefit of the euro-bushings. JMO
Old Sep 1, 2017 | 10:03 AM
Gordy M's Avatar
Gordy M
The C5Z spring with rubber bushings and c6Z shocks are a good street set up. One item you should check out, since your car is setting so low, is the shocks bottoming out on the bump stops? When I started autocrossing, I initially had my ride height and car balance set up by DJRace and he actually raised up mine because it was hitting the bump stops. Also, the car was about 1 second faster compared to my competition at the time. Since I have gone to different shocks and bars for more performance.
Old Sep 1, 2017 | 06:02 PM
EZ2BEVILC5's Avatar
EZ2BEVILC5
Thank you for your responses. I want the car to handle as aggressively as possible. It's my fun car and it is already very stiff. I have a C6 to go and get groceries. It doesn't bottom out and actually sits a little higher than the picture. What was happening was as the AM spring was failing the car continued to get lower. Once I put the stock spring back on it came up. I have Bilstein shocks and AM Panhard rods, VBP sway bars and all urethane bushings.
I guess the only concern for the street is that it is not completely level like the track, so I don't want the car to be so stiff that if you hit a bump the car breaks loose.
Old Sep 1, 2017 | 09:57 PM
marc a's Avatar
marc a
Here is what I inherited from the PO:
VBP Composite Sport Front Spring
C5Z06 Rear Spring
C6ZR1 front swaybar – 33mm
C6Z51 rear swaybar – 25.4mm
C6Z06 Shocks
I installed adjustable sway links so the car could be corner balanced.
Feels just about as planted as my former 944T race car which had coilovers, large adjustable sways, solid bushings, etc., considering the fact that the C5 is on Continentals and the T on Hoosiers. With Hoosiers the C5 would be a beast with this set up.
The ride is tight and you feel bumps but not jarring. Pretty amazing cars right out of the box.
Marc
Old Sep 3, 2017 | 02:00 AM
typeav's Avatar
typeav
I did it back and forth many times, best setup for me was
Z06 Sway bars and links
Z06 Spring Front & Rear
GM Rubber Bushings (Urethane Suck)
Bilstein Shocks B8 Sport
Old Sep 5, 2017 | 04:51 PM
EZ2BEVILC5's Avatar
EZ2BEVILC5
Default Bushings
Why do Urethane suck?
Old Sep 5, 2017 | 06:44 PM
typeav's Avatar
typeav
you can hear the suspension squeak, everytime you hit a hole is like if your tires are running flat. I tried multiple tires from Goodyear run flat to Michelin Pilot Super Sport.
Old Sep 5, 2017 | 07:08 PM
typeav's Avatar
typeav
This parts are for the C6 Z06, ZR1, 2005-2013 and fit the C5
Bolts: 10408968
Nuts: 10408969
Insulator: 10408967
Z06 Rear Spring: 22188038 or 22188078
Z06 Front Spring: 22171750
Z06 Rear Sway Bar: 20777536
Z06 Front Sway Bar: 25919502
I found the Bilstein Shocks B8 Sport to be better than the GM Z06
Z06 Front Shocks: 10313647
Z06 Rear Shocks: 25819268
To Help with suspension set up.....
