Current C4 considering adding C5/6
Old Sep 8, 2017 | 11:06 AM
Gatorlaw's Avatar
Gatorlaw
Default Current C4 considering adding C5/6
I posted initially in the C6 section as that's the newest I could afford right now but many asked why skip C5. My reasoning is that I was trying to get the latest lowest mileage vehicle. So what should I be looking at and what are best years to consider? All input greatly appreciated.
Old Sep 8, 2017 | 11:10 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
once in a C 5 or 6 you won't drive the C 4 much !!!!!
Old Sep 8, 2017 | 11:13 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
each generation has it's own pluses or negatives !!!! We have 2001 Vert, a 99 modified Coupe and a C 6 ZO 6 love driving all of them !!!!!! (the ZO 6 is a Beast !!)
Old Sep 8, 2017 | 11:43 AM
Velocity_Vette's Avatar
Velocity_Vette
Just read the stickies. Ton of info there. Lots of fun things to deal with C5s including;
- Column lock issues (2005 model C6s have this also since they use C5 column).
- EBCM issues
- Parts starting to be discontinued (97-00 SWPS, some body parts, etc).
- etc etc etc
If you want it and can afford it buy a C6. If you want it and want to save a little money buy a C5
Old Sep 8, 2017 | 11:54 AM
dbgoodwin's Avatar
dbgoodwin
You can have fun with either, in a lot of ways they're very similar, but also very different.
Best recommendation is going to be to drive both a c5, a c5z, and a c6, and go with whatever feels best. The one that was the best fit for me was the c5z, but for many a c6 or c5 coupe is preferred.
Old Sep 8, 2017 | 01:17 PM
Shakeydeal's Avatar
Shakeydeal
Everybody will have a different opinion on the merits of C5 vs C6. But my take is that a base C6 doesn't look as good as a C5. Unless you are going for a Z06 or Grand Sport, I would stay in the 5th gen cars. For base C6 money you can get a nicely done C5Z that will outperform the newer car (unless LS3, then it's close) and look much better.
Again, just my opinion.
Shakey
Old Sep 8, 2017 | 01:59 PM
Kmcoldcars's Avatar
Kmcoldcars
Maybe for you, but I have a 1991 and a 2000 convertible and 2002 Z06, and I drive the C4 as much as I drive the others. They are all totally different from each other and all are great driving cars.
Old Sep 8, 2017 | 02:25 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
you maybe small ???
Old Sep 8, 2017 | 03:31 PM
Roddy13's Avatar
Roddy13
The C5 is a great platform. You can get into a C5 Z06 for the same or less than a base C6. This was my rational and I searched exclusively for a C5 Z06 after driving both.
Then I somehow found my FRC C5, priced at almost half of the average asking price of Z06's that were not in anywhere near as nice of shape and I jumped on it. The FRC is basically a Z06 minus the LS6 engine and the manual trans is geared differently. The FRC also has the same suspension as the C5 Z06. Mine has Z06 wheels and 99% of people think it is a Z06... I threw on LG Longtubes and a Vararam which puts me on par with a stock 01' Z06 for power.
Food for thought. I think the Z06 and FRC C5's are the best choice.
Old Sep 8, 2017 | 03:39 PM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
The best advice has to be drive them... Nothing we say is going to change that seat of the pants feeling you get from behind the wheel.
Good Luck and Enjoy!!
Old Sep 8, 2017 | 03:40 PM
dbgoodwin's Avatar
dbgoodwin
the frc uses z51 suspension not z06. There are a ton of small changes that completely change the driving dynamics of the two cars.
Old Sep 8, 2017 | 08:35 PM
acuevo's Avatar
acuevo
It all depends on what you want out of it. An LS3 c6 will have much better HP potential than any c5 (depending on if you mod, and how much you want to spend). BUT if you're a sucker for 80s/90s styling like I am, you'll love a c5. I'm going to ASSUME you are, what with that c4 you have. I love c4 styling and the only reason I have a c5 is because it just out performs the c4 by that much. At any rate, whether you go 5 or 6 they're all solid performance beasts and will be a blast to drive.
Old Sep 9, 2017 | 01:08 AM
Take a few examples of each out for a test drive and see which one really feels good to you. It may be the C5 or it may be the C6 - only you can make that decision. Read the stickies mentioned above too - they will give you a lot of information on which to base your decision.
Old Sep 9, 2017 | 01:18 AM
FX VETTE's Avatar
FX VETTE
Old Sep 9, 2017 | 07:43 PM
cherokee433FL's Avatar
cherokee433FL
Default c5
i have been through 3 c4s, and now have a very nice c5 for 20k. the only downer has been the harmonic balancer, and i have just changed it out simply because of the reputation of the balancer and did not want to worry about it ever again. the c5s are bigger, ride better, have more room, and my wife was really impressed even though she was very hesitant at first. good luck.
Old Sep 9, 2017 | 08:47 PM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
It's hard to go with someone else's preferences. I liked my C4 as much as my C5, but many others feel differently. I also selected the C5 over C6s and C7s I drove, but that's just me. Go with dbdoodwin's suggestion and try "one of each" and see what YOUR best choice is.
Best wishes with your search (plus the fun of driving several Vettes).
To Current C4 considering adding C5/6
