C5 Convertible lid damage
Old Sep 11, 2017 | 05:17 PM
Ruby99's Avatar
Ruby99
2nd Gear
Default C5 Convertible lid damage
I am having a problem with my c5 convertible top and wonder if there is an adjustment. The rear lid that opens and closes to store the top is being damaged by the top in a couple of ways. First, there is a rub mark (paint has worn off) about the diameter of a Pencil eraser on the elevated, curved part of the lid behind the driver. Second, the front edge of the lid actually being broken by the poles that hold up the top. I think it is happening when I open the top. The poles swing back and hit the lid? Ideas? Adjustments? Thanks
Old Sep 11, 2017 | 05:21 PM
Smoken1's Avatar
Smoken1
This thread may help you
http://www.c5forum.com/forum/ubbthre...te_id=1#import
Old Sep 11, 2017 | 07:07 PM
1999corvettels1's Avatar
1999corvettels1
How about pictures of the issues?
Old Sep 11, 2017 | 07:28 PM
Mayor111's Avatar
Mayor111
If you are talking about a "rub" mark where I have indicated (blue circle) in this picture - unfortunately its very common. Every convertible C5 owner I've talked to has that exact rub mark in the same spot.
Old Sep 11, 2017 | 08:27 PM
JR-01's Avatar
JR-01
I didn't think I had that mark, so I just went out and looked. By golly it has started to wear through the clear coat right in that spot..
Old Sep 11, 2017 | 11:28 PM
Ruby99's Avatar
Ruby99
2nd Gear
That is exactly where the rub mark is! And if you moved down around the semi-circle to the left where the hatch ends, that is where the fiberglass is being broken down by the frame of the top.
Old Sep 13, 2017 | 11:46 AM
waupachino's Avatar
waupachino
I have the exact same mark on a 00 with only 35K miles.
Old Sep 13, 2017 | 11:35 PM
Ceedub53's Avatar
Ceedub53
I also have the exact same mark on my C5 convertible.
To C5 Convertible lid damage
