Wide Rear Fender Help please!
Old Sep 18, 2017 | 03:36 PM
RVETTE42's Avatar
RVETTE42
Default Wide Rear Fender Help please!
What vendors would you guys recommend that makes a nice set of wide rear fenders for quality fit and finish. Also could I use my 19/11 CCW wheels.
Old Sep 18, 2017 | 08:03 PM
lewislgZ06's Avatar
lewislgZ06
NCM Lifetime Member
St. Jude Donor '18 thru '26
I like my TPE's, but the fit and finish requires a lot of work, and they're fiberglass. Pete with Carbon Creationz is supposed to be making some like the TPE shape. I'd wait to see his urethane version, if you like that style.
As for your wheels, you'd have to run a 2" spacer on each side if your wheels are flush with your stock fenders, which is not something I would do. I sold my previous CCW's so could get a pair made with the correct off sets that would bolt on, fit right, and look right.
Just my $.02 worth
Old Sep 18, 2017 | 08:28 PM
concour77's Avatar
concour77
I have the L5 and like the look on a C5Z. I would look at all the different makes on your style C5 since there are different body lines. Also, plan for fitment and paint work...there is no such thing as "bolt on" for these.
Old Sep 18, 2017 | 09:15 PM
FYRARMS's Avatar
FYRARMS
Just curious, but why would you add wide fenders if you are just going to use the same wheels you currently have?
Old Sep 18, 2017 | 09:48 PM
calivette805's Avatar
calivette805
I would wait for petes . The tpes have a nice shape to them
Old Sep 19, 2017 | 02:06 PM
STALION's Avatar
STALION
From: ALL governments are legalized mobsters, so doesn't matter where I live :(
There are few forum vendors left to get rear flairs that will deliver. TPE I do not believe are in business anymore, and L5 vendor is super sketchy and wouldn't trust whatsoever. As calivette said forum member Quick Z06 (Pete) is the way to go. There are some re-sellers such but I just go with who you can trust.
Old Sep 19, 2017 | 03:06 PM
RVETTE42's Avatar
RVETTE42
Just wondered if it was possible.
Old Sep 19, 2017 | 06:56 PM
calivette805
U can simply add your desired inches in the lip barrel
Old Sep 21, 2017 | 11:21 AM
STALION's Avatar
STALION
It is possible by using either hubcentric spacers if you have enough thread, or wheel adapters. I ran this way until I bought wheels with proper offset.
To Wide Rear Fender Help please!
