leaking brake fluid
Old Sep 27, 2017 | 05:37 PM
Black76's Avatar
Black76
Default leaking brake fluid
i am leaking brake fluid in the rear i thought it was the flex brake line but when i took the rear tire off and inspected the flex line its good the steel line that goes along the axle is really rusty when i step on the brake pedal i see fluid dripping from the center of the rear end i am not sure where to go from here i guess its the steel brake line but i can not see exactly where the line runs to.
Old Sep 27, 2017 | 05:53 PM
SG Lou's Avatar
SG Lou
the rear lines run above the diff and along the left side of the torque tube tunnel and frame rail up to your ECBM
Old Sep 27, 2017 | 06:00 PM
Black76's Avatar
Black76
where can i find and buy the reformed rear lines
Old Sep 27, 2017 | 06:12 PM
SG Lou's Avatar
SG Lou
You'r not going to find them at any dealer. GM lists the parts as Tubing, Steel, Bulk Roll.
Here is the part # listed at GM Parts Center
https://www.gmpartscenter.net/oem-pa...xoC_OIQAvD_BwE
You have to either buy the tubing, tubing bender and tubing flare kit and do it yourself or buy used from one of the forum vendors.
Side note: No Aftermarket lines are made or sold as far as I know.
Old Sep 27, 2017 | 07:09 PM
twokbolt's Avatar
twokbolt
Hmm if I was you I'd blow a call in to Marc at vettenuts.net. He's probably got a decent used one.
Old Sep 29, 2017 | 03:06 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
That was going to be my EXACT RECOMMENDATION!!
VETTENUTS
Call Marc. He has TONS of good used C5 Stuff and will be able to get you any of the C5 brake line that you need.
If it were me, I would inspect ALL of the ones on the rear cradle just to be sure that they are in good condition.
Bill
Old Sep 29, 2017 | 07:34 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
I have them on my 99 that I am parting out and can see them all...tell me which one you need
To leaking brake fluid
