Rough Idle and Stumble
Old Oct 1, 2017 | 08:25 PM
Dmiles2004's Avatar
Dmiles2004
Default Rough Idle and Stumble
My 2004 coupe recently developed a rough idle and severe stumble at about 1500 rpm under load. Upon checking for a loose plug wire, I discovered two wires which were severely burned. Hesse wires were aftermarket wires from Summit Racing and has only about 20,000 miles on them. I replaced them with A/C Delco 9748MM red wires. Rough idle and stumble are gone and all is right with the world now. These OEM wires were about half the cost of the Summit wire and fit perfectly.
Old Oct 2, 2017 | 02:05 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
good job!
Old Oct 2, 2017 | 02:29 PM
dbgoodwin's Avatar
dbgoodwin
Old Oct 2, 2017 | 04:12 PM
knewblewkorvette's Avatar
knewblewkorvette
Good job
Old Oct 2, 2017 | 04:19 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If the wires are physically contacting the header/manifold, eventually it will destroy the wire. If you do have contact, get some COOL SOX and install it on the boots/wires.
Bill
To Rough Idle and Stumble
