[Z06] Backspace on speedline wheels
Old Oct 15, 2017 | 07:17 PM
cv67's Avatar
cv67
St. Jude Donor '05
Default Backspace on speedline wheels
Anybody know this on the fronts and rears?
Distance from the top of the rim to the back of the wheel hub
Fronts are 17x ?? and rear are ??
Old Oct 16, 2017 | 01:59 AM
dork's Avatar
dork
I saved these stats from some unknown source:
C5 Z06:
Front 17x9.5", 54mm offset, 7.38" backspace
Rear 18x10.5", 58mm offset, 8.03" backspace
From https://www.wheel-size.com/size/chev...corvette/2003/
I found the wheel size and offset for a base c5.
c5 base:
8.5Jx17, ET58mm (offset), 6.53" backspace (?)
9.5Jx18, ET65mm (offset), 7.32" backspace (?)
I converted the backspacing figures above from:
https://www.wheel-size.com/calc/?whe...cl=50mm&sr=0mm
Old Oct 16, 2017 | 09:15 AM
cv67's Avatar
cv67
St. Jude Donor '05
Thanks, D. I have 4.5" on current wheels (A body) sure would like to have a set when the mood comes to go corner. Guess Ill need some type of spacer not sure if thats safe or they make em that big?
Pizza cutters keep me out of trouble but are fun for only so long;get bored easy
To Backspace on speedline wheels
