Planning an HID conversion.
Old Oct 25, 2017 | 09:58 PM
traylbyk's Avatar
traylbyk
Put in Radioflyer's Luminators
55 watt low beam
6000 lumen led high beam
Old Oct 26, 2017 | 02:46 PM
Roddy13's Avatar
Roddy13
HID is dead. You want LED.
Look at all of the new cars coming out, they have started to drop HID in favour of LED.
Who wants ballast issues when you can just run LED bulbs instead.
Old Oct 26, 2017 | 02:56 PM
jrprich's Avatar
jrprich
Good luck finding a lens assembly for an LED bulb that fits a C5.
I doubt an LED bulb in a stock C5 headlamp assembly will produce an acceptable/legal beam pattern.
Old Oct 26, 2017 | 03:30 PM
Tsumi's Avatar
Tsumi
There are no LED projectors that will fit in the Corvette. As far as I know, all the true LED projectors on the market use a 3" lens. The ACAs will only fit a 2.5" lens projector unless you cut into it.
Absolutely correct, despite what other members claim.
LEDs in the ACA projectors will provide barely adequate beam pattern in the sense that there will be minimal glare, but the pattern down the road will be all over the place.
Old Oct 26, 2017 | 05:05 PM
Roddy13's Avatar
Roddy13
The light output is actually excellent. Acceptable yes, Legal I haven't seen anything contrary. Plenty of Video's online, including some with C5's.
There is typically an older generation posting on this forum, but believe me, check outthe Vleds website as a reference... LED is in, HID is out. You can put in almost any made and model of car and get a plug and play LED bulb set. I have converted 3 of my vehicles. HID was last decade and still popular until about 2014-2015. I have LED high's and lows in one of my cars, where I had HID lows and Halogen Highs, its a night and day difference, especially before when you had to wait for the light output of the HID low beams to kick in .. a brief pause while the ballast did its work where you had no light output on a highway... just dangerous. The failed ballasts I went through.... HID is absolute garbage IMO.
Now if you want to talk about those whole projector assemblies posted above with HID bulbs and ballasts, each to their own, but those looks wise, I think they look tacky and cheap.
Old Oct 26, 2017 | 05:20 PM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
Your "pause" issue could have been solved with our Hi-4 harness (keeping the low beams on with the high beams)
The actual danger of LEDs in low beam function has little to do with output or pattern and more to do with the need for a headlight resistor to get the lights to raise/lower. This resistor has to convert nearly at least 50 watts of power into heat for long periods of time which is nothing short of a fire hazard.
Old Oct 26, 2017 | 05:35 PM
Tsumi's Avatar
Tsumi
VLEDs is the last place I would trust for that kind of information.
Your issues are due to your own ignorance on the subject, and you are not in any way qualified for this kind of advice.
Old Oct 26, 2017 | 07:42 PM
jrprich's Avatar
jrprich
What does this comment have to do with a discussion on pros and cons of various types of lighting?
Old Oct 26, 2017 | 11:32 PM
calguy's Avatar
calguy
I think "roddy13" was using age to make a point that older people are more or less set in their ways, and shun some new technology, or idea.
If installing led's is working for him, that's fine, but the older crowd feels safer with what has been proven to work.
Not that led's wouldn't work, but most are content to stick with hid technology.
Bob.
Old Oct 27, 2017 | 12:24 AM
calguy's Avatar
calguy
I am curious what is your basis for stating "VALED'S is the last place you would trust for information.
Could you please explain?
Bob.
Old Oct 27, 2017 | 01:10 AM
Tsumi's Avatar
Tsumi
Bob.
Well, there is being set in one's ways, and then there's being educated. Currently, the only right way to get better lighting in C5 Corvettes is HIR bulbs or an HID projector retrofit with projectors. Until someone makes an LED projector that works with ACA or other projector housings, or Radioflyer (or someone else) designs a headlight around LED projectors, LED headlights do not belong in a C5 Corvette.
FYI, I'm in my mid-20s, so it has nothing to do with my age. I have LED fog lights because I am able to use Morimoto XB LED fogs.
Bob.
Simple. Would you trust the dealership salesman that claims the Prius he is selling can outrun the Corvette? They're in the business of selling you their LEDs, they obviously wouldn't point out any flaws with it, the exact opposite in fact.
Old Oct 27, 2017 | 01:44 AM
calguy's Avatar
calguy
And you know this for a fact, or are you just assuming this?
The reason I ask is I am interested in this led bulb that I see videos of on youtube.
A 15 bulb comparison is a pretty good judge of how these bulbs operate in any vehicle, which are good, and which to stay away from.
In all the videos I watched, not one stated anything about a projector lens specific to any vehicle, or that a special projector lens was needed.
Old Oct 27, 2017 | 02:30 AM
  #33
Tsumi's Avatar
Tsumi
LEDs do better than HIDs in halogen housings, that much is true. However, they are still not better than halogens. The light pattern is off (most people do not know what to look for), and whiter does not necessarily mean brighter. LEDs and HIDs also tend to throw a lot more foreground light, which many people mistake for better lighting. Yes, it makes better lighting right in front of your car, but all that does is compromise your vision down the road. By the time something enters the foreground area at highway speeds, it is impossible for you to avoid.
You can watch the video below for a comparison. This is also in a best case scenario, as projectors are able to focus light better than reflectors regardless of light source. If LEDs do that badly in projectors, you can extrapolate how much worse they would do in reflectors.
Old Oct 27, 2017 | 02:58 AM
  #34
calguy's Avatar
calguy
Once again, do you have definite proof that VLED'S is not a company to do business with.
Using your advice, then it would also apply to the Radioflyer led business, as well as any other business selling led's.
If you have a beef with some company, let all of us know who, and what that company did, that turned you against them.
Have you had actual dealings with VLED'S?
Bob.
Old Oct 27, 2017 | 03:16 AM
  #35
Tsumi's Avatar
Tsumi
Bob.
Now you are putting words in my mouth. I did not say anything to that effect. All I said is that I would not trust their claims that LED headlight bulbs are superior to halogen headlight bulbs in halogen housings.
I have nothing against the company as a whole, nor do I have a problem with their other LED products. If I thought one of their other LED products suited my needs, I wouldn't hesitate to purchase it.
The beef I do have are people that run HID and LED bulbs in housings that are not meant for them. It is annoying and downright dangerous.
Old Oct 27, 2017 | 02:29 PM
  #36
calguy's Avatar
calguy
I don't think I am putting words in your mouth.
Read your previous post#27, you stated VLED'S is the last company you would trust for "that kind of information".
Now do you have a reason for stating that, or are you just flapping your gums with unsubstantiated proof that this company is doing anything that would cause us not to shop there?
Like I said, if you had a problem with this company, it would be nice to know so the rest of us in the market for lighting, could get a head's up.
Bob.
Old Oct 27, 2017 | 03:10 PM
  #37
jrprich's Avatar
jrprich
Jeez guys, what is with the hostile replys and comments??????
We are all here to help and learn. There are always many ways to do anything
To Planning an HID conversion.
Old Oct 27, 2017 | 03:12 PM
  #38
FX VETTE's Avatar
FX VETTE
Old Oct 27, 2017 | 03:19 PM
  #39
Tsumi's Avatar
Tsumi
Bob.
Really? REALLY? ARE YOU THAT INCAPABLE OF READING AND COMPREHENDING!?
Did you not read the post I quoted? He said "check outthe Vleds website as a reference... LED is in, HID is out." No, LEDs are not in. HIDs are not out. Neither are halogens.
And if you think I'm being edgy, that's not even half of it right now. I just got majorly pissed off by my boss, so think before you respond next time. Or you might earn yourself a block, because I don't come on this forum to deal with willful stupidity, I deal with enough of that crap at work.
Old Oct 27, 2017 | 03:27 PM
  #40
Z06PSI's Avatar
Z06PSI
St. Jude Donor '17-'18-'19
