2002 Rear Hatch Strut replacement
Old Oct 27, 2017 | 11:08 PM
motogib1's Avatar
motogib1
Default 2002 Rear Hatch Strut replacement
The struts to support the hatch in my 2002 Coupe have failed. The bottom of the struts are difficult to access because of the speaker enclousures. Is it possible to pry the enclosures open in the back to gain access without going to the trouble of removing the entire enclosure.
Thanks,
Motogib
Old Oct 27, 2017 | 11:14 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Thanks,
Motogib
its possible but not easy...you need to pop the clips loose and then pull them off the ball, not sure you can do it with messing something up.......I have a set of struts for sale if you are interested $40 to your door..can ship tomorrow...just PM me if you want them
good luck in any case
Old Oct 28, 2017 | 01:34 AM
Rob 02's Avatar
Rob 02
^Yeah. Use a bent screwdriver type thingy to pop the clip out a little and it comes right off if you tap it.
Old Nov 13, 2017 | 11:21 PM
motogib1's Avatar
motogib1
So I replaced my worn out struts with ones from MidAmerica. Was tricky but got them both on. The hatch went up and down with one but was stuck in the open position with both struts on. So the repair failed. I guess I am going to take the car to the dealer and get the job done. Don't know if I got faulty struts from MidAmerica or what but there is only on way to install them.
Old Nov 13, 2017 | 11:36 PM
Choreo's Avatar
Choreo
On the surface, sounds like one of the struts is bad? Might try removing one end of the known good strut, if the hatch still does not start to go down with the additional weight, probably a bad strut. If you could confirm it that way, you could temporarily swap out the bad one with one of your old ones temporarily until you can return it for replacement?
Old Nov 14, 2017 | 12:28 AM
Rob 02's Avatar
Rob 02
It sounds like one is seized up.
To 2002 Rear Hatch Strut replacement
