Painted top C5
Old Oct 30, 2017 | 02:14 PM
Can't drive 55's Avatar
Can't drive 55
Default Painted top C5
Has anyone painted the glass top to match the car? How did it turn out?
Old Oct 30, 2017 | 02:41 PM
Tsvetteman's Avatar
Tsvetteman
Default Painted top
you can buy painted tops or glass tops on eBay . My C5 came with a glass top
I have an extra top which matches perfect from eBay
Old Oct 30, 2017 | 02:43 PM
JuggernautOfWar's Avatar
JuggernautOfWar
Well my glass top is tinted black and my paint is black, so I guess it matches. Is what what you meant?
Old Oct 30, 2017 | 02:55 PM
Can't drive 55
Default Painted top
Thanks guys... mine is Red...
Old Oct 30, 2017 | 03:01 PM
iAmGeranimo's Avatar
iAmGeranimo
Google the C5 Targa Top.
Old Oct 30, 2017 | 06:10 PM
knewblewkorvette's Avatar
knewblewkorvette
Old Oct 30, 2017 | 06:51 PM
Chris Draper's Avatar
Chris Draper
From: Gilbert, Arizona Currently Own: 1998 Coupe YouTube: My Corvette Life
You would be better off using a vinyl wrap than painting.
Old Oct 30, 2017 | 07:49 PM
You can paint a glass top, wrap it in vinyl, or try and refinish it if it is showing signs of wear. Here are some files that may give you some ideas. Of course, you can always buy a fiberglass top and paint it to match the car if you already have a glass top.
Old Oct 31, 2017 | 01:07 PM
Can't drive 55
Default Top
My top is perfect, I just don’t like it. I think a matched top looks so much better. One of the members has a C5 with a Torch Red top and I really like the look. I’ll ask a body shop if they can paint it.
Old Oct 31, 2017 | 08:34 PM
hornet7's Avatar
hornet7
Default Vinly Wrap.
Started to use a Vinyl wrap on my Targa top and halo but stopped because I did not like the scratches on the Vinyl, I had purchased a gloss black 3m material. Does anyone know if the vinyl adhesive will damage the paint on the Halo?
Old Nov 1, 2017 | 12:43 AM
chasboy's Avatar
chasboy
Oldtimer
I’m curious. Aside from the regular painted top, is there a plastic/lexan AND real glass?
Old Nov 1, 2017 | 11:56 AM
c4cruiser's Avatar
c4cruiser
C4's and C5's came with the solid top as standard equipment. The clear top was an option. In some of the C4 years, a clear top came in either a blue or bronze tint.
But the clear top is not glass. It's a lexan type of material. So if it gets hit or dropped, it won't break into hundreds of small pieces like a glass car window would do.
In painting a tinted top, whatever color goes on first (either body color or primer) will be seen from the inside and will have a color tint to that paint because of the tinted top material. And a paint shop will most likely sand the top to make sure that paint adheres. You may see the scratches from the sanding when looking at the underside of the lexan top.
I think it would be easier to just find a solid top and have it painted to match the car. Then you can swap between the solid top and the tinted top when it suits you.
Old Nov 2, 2017 | 04:12 AM
ErikwithAK01's Avatar
ErikwithAK01
Only 2 tops were built for the C5. One is made from sheet molding compound, which is the stock base model piece, and the optional top was made from Lexan.
The lexan piece is notably lighter, and gives ya more room for a helmet, but cooks ya alive in the summer. It is also susceptible to crazing (what looks like thousands of superficial spider web cracks due to UV exposure).
I have refinished my top twice. Once after using it to design a negative for a mold to make one out of carbon fiber, and another time a few years later because I decided it would be easier to paint it with clear, than to polish it more often as bare material.
I also used black 3m vinyl wrap for the halo. It literally took me 45 minutes in my driveway one day when I was bored. Windows are 35% sides, 25% hatch.
Old Nov 2, 2017 | 06:30 PM
chasboy's Avatar
chasboy
Oldtimer
thanks guys
Erik, what color is your top now, and does it match the halo?
I have the padded headliner from Mamotors, took it out twice to ‘experience’ the tinted top and yup, got roasted. I would expect it to be cold in the winter. I just remove the top now when I want max air and view.
Old Nov 2, 2017 | 06:46 PM
Chris Draper
No, vinyl will not damage the paint. Maybe if it was ever repainted, when removing the vinyl I'd be a little more cautious so it didn't pull off any paint that didn't make good adhesion.
Old Nov 2, 2017 | 07:39 PM
SG Lou's Avatar
SG Lou
Why don't you contact Marc Rose over at Vettenuts. He runs a Corvette Recycling yard and he's a forum vendor. He just might have a nice Torch Red top available.
http://www.vettenuts.net/index.php?l=product_list&c=3
Old Nov 2, 2017 | 09:42 PM
ErikwithAK01
Mine is literally just polished out, and clear coated. With the window tint, the top looks bpack too. You cant tell it is dark blue, until you are looking out of it from inside tue car.
To Painted top C5
